LinkBack | Thread Tools |
#1 (permalink) |
Hi guys, had a quick question.
I had to fill up my transmission with the ATF SP III fluid. I added some, and then started the car, warmed it up and went through all gears(P, R, N, D, 2, L). I then checked the level on level ground and shifter on "N". It was in the midway mark of the "Hot" on the dipstick. So, I thought all is good. However, I checked this morning while the engine was cold, and the fluid is "WAY OVER" the hot line. It is like 1.5 inches over it. From what I understand, the "cold" mark on the dipstick is actually below the "hot" mark. So, why is this happening? Does anybody know? I am just curious to know if I somehow screwed this up. Thanks, Ashish M. |
| Sponsored Links | |||
Advertisement | |||
#4 (permalink) |
Drives 01' Accent GS 1.6 DOHC
Well according to the book, you should check it on a level surface in neutral. Also, if you put the recommended amount of fluid in, I wouldn't worry about it. As long as you don't hear any banging and it shifts and sounds fine, let her rip. I foyu atill aren't convinced, call your local tranny shop. I'm sure they can explain it over the phone better than I can.
#5 (permalink) |
12 Veloster
08 Accent GLS(R.I.P.)
08 Bullitt Mustang
04 Yamaha FZ6
82 Dodge D150
83 Iveco Z110
Because the level will be lower if the fluid is COLD (with engine running, trans in Neutral) than it will be once it has gotten HOT and expanded (again, with engine running, trans in Neutral).
Parfois, on fait pas semblant! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
