LinkBack | Thread Tools |
#1 (permalink) |
hyundai accent 2005
I have hyundai accent 2005 1341cc 86hp, with BRC LPG kit.
When i start the car at the morning, the engine misfiring around 500rpm for a few second (5sec-10sec) sometimes the engine start ok in the 1100rpm - 1200rpm and when i touch the accelerator then misfiring again! The car have 133.000km (11.000km with LPG). I have replace the petrol filter 2 days ago and the all electric system without multiplier. I have clean throttle valve and the injectors with stp cleaner. |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Drives '09 HD Elantra 2.0L G4GC
Drives '01 Accent 1.5L G4FK (RIP)
I'm not sure what your LPG setup is there, but over here on cold starts most people start the car on unleaded, then once it's warmed up a little switch over to LPG. Cars that are designed for LPG from the factory (such as the Ford Falcon) don't have this issue - just the converted ones.
#5 (permalink) |
How's the condition of your spark plugs? LPG tends to overheat many plugs as it's a higher octane fuel, causing you to replace them more frequently. Use a voltmeter to check the resistance of your ignition leads while you're at it.
#6 (permalink) |
Drives 01' Accent GS 1.6 DOHC
My Hyundai Accent does the same thing on a chilled moist morning. When you start it, it will idle low, sputter and shake like a misfire, idle up and then down and does the same thing again. It only does that like 2 or 3 times. I believe it's moisture in the gas tank or something like that. run a can of dry gas thru her.
#7 (permalink) |
hyundai accent 2005
i have replace the spark plugs ~1000km, 10 days ago! and the problem there's still! no one difference! i use stp cleaner in unleaded tank! i have run for 250km! no difference again in the next morning... i replace the unleaded filter with no difference again!
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
