Accent 2004 won't start - Hyundai Forums : Hyundai Forum
Old 10-13-2011, 09:05 PM   #1 (permalink)
Drives Accent 2004 gs
yanzx is on a distinguished road
Default Accent 2004 won't start
My hyundai accent 2004 standart doesn't start. The engine crank, but there's no fire. I change the camshaft and crankshaft sensor. Also change my timing belt, my alternator, my starter, my control box and my computer. But if I pull the car with my pickup, it runs. While the engine is running, the computer doesn't give me any diagnostic code. Someone have any idea?
I also check my fuse, relay,... Even jump start the starter to check if it was the switch.
yanzx is offline   Reply With Quote Quick reply to this message
Old 10-13-2011, 09:56 PM   #2 (permalink)
Wow that's a strange one.
When its cranking over is it turning fast enough ; try boosting it when starting to make sure battery amperage is there.
It starts immediately with a tow , or you only tried it once ? With window is down can you hear fuel pump pressurize for 3-4 seconds before starting. Were the sensors changed dealer parts or aftermarket. Control box ? means your ECM or main computer ?
In a dark garage if possible remove one plug wire, put on a good spark plug and lay it against metal under hood. Hold with insulated pliers or heavy glove if brave. You should see a bright blue spark , not yellow or orange. Weak coil if spark isn't blue.
Lastly what is the engine compression , even cold numbers are useful. Weak compression makes for bad starting, especially in cold weather when clearance increases.
santa06 is offline   Reply With Quote Quick reply to this message
Old 10-13-2011, 09:58 PM   #3 (permalink)
jsinton's Avatar
Weird, unexplainable electrical problems in a Hyundai? You live in Canada?
I'll give you 5 to 1 odds you have a bad ground, like a negative battery cable bolted to the body. If it was my car, I'd completely disassemble the battery cable connections, clean them real good, and reinstall with dielectric grease. Happens a lot to Hyundai, methinks.
Old 12-29-2011, 10:19 AM   #4 (permalink)
2005 Nissan Titan and 2004 Hyundai Accent
fsumitch is an unknown quantity at this point
Im having the same problem with my car. It cranks but wont start. I have an 04 accent. checked the timing belt, have new plugs and wires, changed the fuel pump as I thought at first it was the fuel pump but obviously it wasnt. Im gonna try cleaning the ground connections and see if that works. Im stumped!!!!
fsumitch is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 01:34 PM   #5 (permalink)
Cleaned all the ground connections and no luck!
