2004 Hyundai Accent Won't Start - Hyundai Forums : Hyundai Forum
Old 06-22-2011, 07:39 AM   #1 (permalink)
bnk26
hi all new to this forum, just bought a 2004 hyundai accent 1.6L standard transmission on the 13th of June, ran great drove it everyday, was driving fine when I came home monday night, went to drive it yesterday and get nothing, turn the key no click, no crank, the radio turns off as it always did when you try to start, I checked the fuses, and the battery shows twelve volts on the meter, any ideas what could cause this to abruptly happen?
bnk26 is offline   Reply With Quote Quick reply to this message
Old 06-22-2011, 09:57 AM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
welcome to the forums
try the obvious first, get some jump leads and getting a buddy to give you a jump start............does it start?, if so flat battery, if not likely to be the starter motor
MONTEGO
Old 06-22-2011, 10:17 AM   #3 (permalink)
bnk26
QUOTE (Montego @ Jun 22 2011, 08:57 AM)
thanks for the reply, as I stated, tested the battery, but didn't mention even though it showed 12 volts I did try jumping it, tried pop starting it also. I was planning on towing it to my father in laws which is a much better place to work on a car, and take the starter off and have it tested, but was hoping maybe someone else had this happen and it was more simple wishful thinking I guess
Old 06-23-2011, 01:16 PM   #4 (permalink)
Alfons is an unknown quantity at this point
QUOTE (bnk26 @ Jun 22 2011, 10:17 AM)
Did you have a load test done on that battery? The fact that it shows 12 volts doesn't tell you very much and it's a lot easier to try starting it with some jumpers than taking off the starter - you could also borrow a known good battery and try starting it with that.
Alfons is offline   Reply With Quote Quick reply to this message
