P0501 Speed Sensor. - Hyundai Forums : Hyundai Forum
Old 03-28-2010, 06:45 PM   #1 (permalink)
RetsaM's Avatar
RetsaM
Send a message via MSN to RetsaM
Hello,
The MIL light up and I got the P0501 Code. (Speed Sensor)
I use a ScangagueII and the Speed is 0 KM/H at any speed. (was working before)
But the in dash Speed meter work no problem.
I look on the HMAservice web page and did not found were is located the Speed Sensor.
Somebody know?
I do not know if it is related but I change my tire for my summer tire before the MIL light up...
Thank you,
Jonathan Lévesque
RetsaM is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 08:32 PM   #2 (permalink)
rsquared's Avatar
rsquared
It's in the transaxle. This might also help http://www.obd-codes.com/p0501
There's never enough time to do it right, but there's always enough time to do it over.
www.myhyundaiforums.com
rsquared is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 08:44 PM   #3 (permalink)
RetsaM's Avatar
RetsaM
The cable that go from the dash speed meter, yes, go to the transaxle and that one is working good!
But the speed I got from the computer when I drive is 0 KM/H.
I reed somewhere the 1.6L as the mecanic VSS for the dash speed meter
and a digital VSS for the computer... but where it is?
JL
Old 03-28-2010, 08:57 PM   #4 (permalink)
rsquared's Avatar
rsquared
Look under the air filter box. go to hmaservice and search vss.
Old 03-30-2010, 07:27 PM   #5 (permalink)
RetsaM's Avatar
RetsaM
I look under it and I found something but it don't look like a speed sensor... it only have 2 wire instead of 3.
In the HMAservice site it show it could be at 3 different place... one on the transmission, on the speed sensor (reed switch) or at the front right wheel (ABS I supposed)
BTW I don't have ABS and it is a manual transmission...
Somebody got that problem ?
Thank you,
Jonathan Lévesque
Old 03-30-2010, 08:29 PM   #6 (permalink)
rsquared's Avatar
rsquared
Sorry, I don't know why but I was thinking you had an automatic. Check TSB 00-36-011
Old 04-04-2010, 07:56 AM   #7 (permalink)
RetsaM's Avatar
RetsaM
I finally get some time to work at it Yesterday.
It was some rush and oxydation on the Reed contact switch behinde the cluster guage.
It is fix not and I have speed reading on the ScanguageII
The car is acting much more smoothly also.
Thanks for your help,
Jonathan Lévesque
Old 04-04-2010, 12:44 PM   #8 (permalink)
jsinton's Avatar
Exactly, the VSS is different from the ABS wheel sensors on this car. It's just like he says: On the back of the instrument cluster. The pic above is a reverse lamp switch.
jsinton is online now   Reply With Quote Quick reply to this message
Old 04-04-2010, 10:06 PM   #9 (permalink)
RetsaM's Avatar
RetsaM
Thanks for the info I did not get any idear what the heck was that connector...
Humm...
I should connect a switch on that wire
so if somebody is fallow me in my but, I can turn on the reverse light...
