LinkBack | Thread Tools |
#1 (permalink) |
I have a 2001 Accent , blown head gasket cracked head. Its 1.5 L Can I swap in a 1.6 motor without having to do any modifications. Can has 5 sp manual transmission. If possible do iI need to swap out the ECU , any wiring issues? Thanks Dave
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
QUOTE (damham @ Dec 16 2009, 04:31 PM)
#5 (permalink) | |
QUOTE (svt28 @ Jan 16 2010, 08:34 PM)
There's never enough time to do it right, but there's always enough time to do it over. www.myhyundaiforums.com |
#6 (permalink) |
Drives Accent
I did a similar swap. I have an 2001 Accent that came with a 1.5L but now has a 1.6L. Funny thing is, I bought a manual transaxle for a 1.5L and hook it up to the 1.6L engine. I have to throttle all the way up in order to shift now. Gears would slap and grind. Sometimes I couldn't even shift into gear. I thought maybe I put the new clutch in backwards, so I took it apart and it was in the right way. Clutch shows signs of uneven wear, and the teeth on the flywheel were scarred. Does anyone know what went wrong? It is a used transaxle so maybe its just bad. I may make a post of it.
#7 (permalink) |
If the teeth on the flywheel are bad then there is an issue with your starter.
Sent from my iPhone using AutoGuide.com App |
#8 (permalink) |
Drives Accent
Yeah, it might be a separate problem. I'm still reading up on it right now and my next suspect is the speed sensor since the gear ratios between the 1.5 transaxle and 1.6 transaxle differ slightly.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
