Crank Shaft Bolt Helppp - Hyundai Forums : Hyundai Forum
Old 11-08-2009, 01:15 PM   #1 (permalink)
cughter
Is the bolt on the crankshaft pulley reverse thread? (2004 Hyundai Accent 1.6L)
The pulley turns clockwise when starting so it would make sense that clockwise = tighter and counterclockwise = looser.
cughter is offline   Reply With Quote Quick reply to this message
Old 11-08-2009, 01:58 PM   #2 (permalink)
mac1
no not reverse thead at all. Having a tough time removing it? heat it up with a torch.
QUOTE (Cughter @ Nov 8 2009, 02:15 PM)
'99 Sonata 2.4L - sold
'01 Sonata 2.5L - sold
'01 XG300 - sold
'96 Accent 1.5L- sold
'01 Accent 1.6L auto - on it's 3rd engine and 2nd trans
'01 Santa 2.4L - sold
'03 Tiburon Gtv6spd - sold
'93 Probe GT, caged, lexan'd, turbo'd v6, lightweight
mac1 is offline   Reply With Quote Quick reply to this message
Old 11-08-2009, 03:41 PM   #3 (permalink)
cughter
Yeah i assumed it wasn't but the guy helpin me out was SURE it was reverse threat just cause its soooo tight haha. but yeah this is the second crankshaft pulley bolt ive ever had to remove and i've never had this much trouble on it.
on a 4cyl 2door car too imagine that.
that sounds like a pretty good idea i'm definitely going to try it out.
Old 11-08-2009, 05:51 PM   #4 (permalink)
ADMINISTRATOR
Montego's Avatar
you may well need some sort of inpact wrench to remove this bolt, they can be very tight. heating up the bolt is not a good idea because you run the risk of damage to the crankshaft oil seal
MONTEGO
