Multiple Warning lights - Hyundai Forums : Hyundai Forum
Old 02-08-2013, 02:23 AM   #1 (permalink)
Drives Accent
WildFire1980 is an unknown quantity at this point
Question Multiple Warning lights
My Wife's Accent '00 suddenly has multiple warning lights coming up on the dashboard.
First the ABS & Handbrake lights came on, then about 5 min later the Engine & Airbag lights switched on. Once the car has warmed up, the ABS & Handbrake switch off when I come to a stop, but come on again when I accelerate. There is also a belt that is slipping when cold.
Could the above have anything to do with the slipping belt or electrical fault. It just seems strange to have so much fail at the same time. Any suggestions or ideas on what is happening would be greatly appreciated??
WildFire1980 is offline   Reply With Quote Quick reply to this message
Old 02-08-2013, 04:51 AM   #2 (permalink)
The_AirHawk's Avatar
12 Veloster 08 Accent GLS(R.I.P.) 08 Bullitt Mustang 04 Yamaha FZ6 82 Dodge D150 83 Iveco Z110
The_AirHawk is an unknown quantity at this point
Alternator belt needs tensioning and/or replaced.
Change all of them, if you change one. They're not expensive.
Parfois, on fait pas semblant!
The_AirHawk is offline   Reply With Quote Quick reply to this message
Old 02-08-2013, 02:12 PM   #3 (permalink)
Drives 1998 Accent GS SOHC
tedav is an unknown quantity at this point
Hi Wilfire80. If your charging system or battery is not working correctly that could cause the Electronic Control to not work.
Like Airhawk said check the belts. Check your battery and charging system.
tedav is offline   Reply With Quote Quick reply to this message
Old 02-10-2013, 06:15 AM   #4 (permalink)
Drives Accent
Thanks for the advice guys. Pity it's bucketing down with rain today!!!!!
Speaking of rain, Will it have an effect on the braking of the car??
Old 02-10-2013, 09:50 AM   #5 (permalink)
'12 Elantra Sedan '12 Chevy Malibu '11 Kawasaki Vulcan 900 And yes, I drive them all.
Easy Rider is an unknown quantity at this point
And then test the charging voltage AND the battery.
If the battery is more than 5 years old, it might need replacing too.
P.S. If the alternator is not charging AND the battery is getting weak, it may stop altogether at some point (soon).
Easy Rider is offline   Reply With Quote Quick reply to this message
Old 02-10-2013, 10:13 AM   #6 (permalink)
Drives Accent
Just realised how badly I asked the above question. Rain always effects braking😜
Will the lack of charging/slipping belts have an effect on the braking system??
Old 02-11-2013, 11:41 AM   #7 (permalink)
The fluid level sensor and the ABS are part of the electrical system. If you have electrical issues, the indicators could light when there is no issue, and the ABS may not function, but I don't believe the basic function of the brakes would be affected.
If your accent is a 2000, you might have more input from others in the LC board.
