LinkBack | Thread Tools |
#1 (permalink) |
Drives Accent X3
Hey all first time lurker now first time poster. Anyway...
I've called a few places and surfed the net trying to find the size of the lower alternator bolt in my Accent. Went to do a belt replacement and the bolt that goes in under the alternator is missing. I haven't had the car long and my mechanical knowledge is fairly limited. I think it's supposed to be 12mm but I'm not sure on the length or anything else so I can buy a replacement. I checked the online service manual sticky and couldn't find the size. Thanks for your help. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
1997 Hyundai Accent L 1.5L SOHC (currently at 220,XXX miles)
Your referring to the Alternator Anchor bolt right?
I have a 97' X3 L model and I've had to change it out like one time. I currently have this set up: Bolt Shop The Hillman Group 1/2"-20 x 4" Zinc Plated Standard (SAE) Hex Bolt at Lowes.com Nut Shop The Hillman Group 2-Count 1/2"-20 Zinc Plated Standard (SAE) Hex Nuts at Lowes.com Lock Nut Washer It says it comes in a 4 count pack but you should be able to get just one if the associate is nice enough to do that. Shop The Hillman Group 4-Count 1/2-in Standard (SAE) Split Lock Washers at Lowes.com Washer It says it comes in a 4 count pack but you should be able to get just one if the associate is nice enough to do that. Shop The Hillman Group 4-Count 1/2-in x 1-in Zinc Plated Standard (SAE) Flat Washer at Lowes.com Hope this helps!!!
#3 (permalink) |
12 Veloster
08 Accent GLS(R.I.P.)
08 Bullitt Mustang
04 Yamaha FZ6
82 Dodge D150
83 Iveco Z110
If you want to "keep it metric" Lowe's has those as well. Note that most-everything they carry is Metric 8.8 or lower. Sufficient for an alternator bolt - but they should be avoided for "critical" items like brake or suspension bolts.
Parfois, on fait pas semblant! |
#4 (permalink) | |
I felt more comfortable using SAE cause it was easier at the time, and it was less confusing trying to pick the proper one. |
#5 (permalink) |
12 Veloster
08 Bullitt Mustang
04 Yamaha FZ6
82 Dodge D150
83 Iveco Z110
No problem with that - I was merely pointing-out that they had metric, and the grade (for anyone ELSE that may be missing particular fasteners).
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
