Rear View Mirror - Hyundai Forums : Hyundai Forum
Old 01-08-2008, 09:48 PM   #1 (permalink)
2007 Entourage Limited 2008 Sonata SE 3.3 2008 Elantra 2010 Tucson
timk22 is an unknown quantity at this point
Does anyone know exactly how to remove the rear view interior mirror, including the base atached to the winshield, from a 4g Sonata?
Hate to tug, pull and pry and eventually damage the windshield..........
Tried searching, but could not find a single good post about removing the mirror.
Want to install auto dimming w/homelink.
Thanks,
timk22
timk22 is offline   Reply With Quote Quick reply to this message
Old 01-08-2008, 09:58 PM   #2 (permalink)
Brazzel's Avatar
Brazzel
http://www.hyundaitechinfo.com/ <~~ Register on this site...go to shop and then body electrical and you will find what you are looking for.
Brazzel is offline   Reply With Quote Quick reply to this message
Old 01-08-2008, 10:32 PM   #3 (permalink)
Thanks, but had checked that out previously.
This doesn't tell you how to actually remove the mounting base attached to the windshield.
I'm thinking of applying heat from the outside to help "soften" the adhesive and see what happens.
timk22
Originally posted by Brazzel@Jan 8 2008, 10:58 PM
[b]http://www.hyundaitechinfo.com/* <~~ Register on this site...go to shop and then body electrical and you will find what you are looking for.
[snapback]128702[/snapback]
Old 01-08-2008, 10:38 PM   #4 (permalink)
Brazzel's Avatar
Brazzel
Originally posted by timk22@Jan 8 2008, 10:32 PM
[b]Thanks, but had checked that out previously.
timk22
[snapback]128711[/snapback]
And what is the new mirror to attach too ? I have the auto dimming w/homelink mirror in my Azera and it is attached to what you are wanting to remove.
Old 01-08-2008, 10:39 PM   #5 (permalink)
SonataRobbie's Avatar
Drives 06 Sonata GLS 3.3; 11 Gen Coupe Track 3.8
SonataRobbie
Originally posted by timk22@Jan 8 2008, 08:48 PM
[b]Want to install auto dimming w/homelink.
[snapback]128699[/snapback]
timk22,
I'm not sure you'll be able to upgrade if you don't already have the homelink mirror in the car - I don't think the wiring would be there. If you are able to do the upgrade, please let us know what was involved. I'd like to do this to mine as well (I just have the standard mirror in mine).
And I think Brazzel is right. The new mirror should fit on the same windshield mount. And just in case it doesn't, I'm not sure how you'd remove it. You can't just "soften the adhesive" - it's an epoxy that might as well be part of the glass once it's cured.
Thanks,
Robbie
SonataRobbie is offline   Reply With Quote Quick reply to this message
Old 01-08-2008, 11:08 PM   #6 (permalink)
The replacement mirror I picked up has it's own mounting plate, which is a different size than the original 08 non-ECM Sonata plate. The one I picked up actually came off of an 05 XG.
I'll have to run the wiring, but that's easy enough (only 4 wires and I might not bother with the reverse wire).
timk22
Old 01-08-2008, 11:13 PM   #7 (permalink)
Brazzel's Avatar
Brazzel
Originally posted by timk22@Jan 8 2008, 11:08 PM
[b]The replacement mirror I picked up has it's own mounting plate, which is a different size than the original 08 non-ECM Sonata plate.* The one I picked up actually came off of an 05 Sonata I believe.
timk22
[snapback]128731[/snapback]
Well if I were you I would place the new mount under or above the OEM. More than likely you are going to take a chunk of windshield along with the old mount if you try and remove it. Goodluck.
Old 01-09-2008, 08:30 PM   #8 (permalink)
Turns out that the existing mounting plate is the exact same size after all.
It looked like a different size until I removed the existing mirror and compared it to the ECM plate.
Just saved me a big headache trying to remove and replace it!
All I have to do now is run the wiring - no big deal - and I'll have an ECM with Homelink.
Thanks for your inputs.
Old 01-09-2008, 08:37 PM   #9 (permalink)
Brazzel's Avatar
Brazzel
Originally posted by timk22@Jan 9 2008, 08:30 PM
[b]Turns out that the existing mounting plate is the exact same size after all.
All I have to do now is run the wiring - no big deal - abd I'll have an ECM with Homelink.
[snapback]128889[/snapback]
LOL...Well that's a good thing cause you would had a fight on your hands getting that thing off. Let us know how the rest of the install goes......I have my windows tinted so dark I hardly need mine...but I like it none the less. Don't have anything hooked up to the homelink...guess I could turn a lamp or two on. [attachmentid=5954]
Old 01-09-2008, 09:15 PM   #10 (permalink)
madderhatter
Guest
Posts: n/a
Man, do I dig the homelink. One button for the garage door and one button for the security system, and one button left.
If you get it working post up a DIY.
