LinkBack | Thread Tools |
#1 (permalink) |
My 2006 Sonata GLS headlights dim along with the entire lighting electrical system when my car slows down past 1500 RPM. Does anybody know why??? I had the car worked on 2 weeks after i got it because of this and they replaced a timing chain thinking this was the problem, but it wasnt.
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
They ... replaced ... the ... timing ... chain for an electrical problem?!? I hope they didn't change you for the work (no pun intended.)
What's next, replace the muffler b/c the horn don't work? Bad alternator. Wait a minute ... are you SURE they replaced your timing chain and not your serpentine belt? Even that's a stretch (pun intended.) Finding a short's NBD. Find another Sonata and use an ammeter in place of each fuse to measure and compare the draw/change, one circuit at a time. No doubt there's one that's WAY different. The drain lieth within that circuit.
I hear and I forget, I see and I remember, I do and I understand. Co NF ucius |
#6 (permalink) |
Lifeguard...
Just curious, do your lights dim and STAY DIMMED below 1500 rpm? The reason I ask is that I experience somthing similar in that when I remove my foot from the accelerator, and am slowing down (I haven't noted exactly what RPM this happens at), I sometimes notice my lights dim for a fraction of a second, then kick back up to normal intensity. It's just a short dim, less than a second. Thanks... |
#10 (permalink) |
Definately alternator, use a multimetre on the battery terminals to check the resistance and the fluctuations, also open all doors and open and close windows at stationary with car running if the lights almost turn off or windows are slow at open or close then it is definately the alternator...
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
