Clunk in the front suspension? - Hyundai Forums : Hyundai Forum
Old 05-29-2013, 01:52 PM   #1 (permalink)
Drives YF 2014 Sonata Ltd Turbo Drives NF 2007 Sonata Ltd
wcw1
Question Clunk in the front suspension?
I have a 2007 Sonata Ltd (63000 miles) and had a clunk in the front suspension. I had the front upper control arms replaced (which were visually badly worn) and that fixed the problem. But now, a several months later another similar clunking noise has developed when I go over those small speed bumps in parking lots.
Any thoughts on this problem.
wcw1 is offline   Reply With Quote Quick reply to this message
Old 05-29-2013, 02:30 PM   #2 (permalink)
v33sonata's Avatar
Drives: 2006 Hyundai Sonata V6, 2013 Kia Rio, 1985 AE86 20v BT, 2002 GSF1200, 2004 SV650
use the search option you will find a ton of threads on this.
v33sonata is offline   Reply With Quote Quick reply to this message
Old 05-29-2013, 07:29 PM   #3 (permalink)
wcw1
Question
Hi v33sonata
I tried searching before I posted and again after your response. While there are a ton of threads on suspension noise, none seem to be on point. They all seem to point to upper control arms. You even posted the upper control arms in one thread.
Since I have already replaced the upper control arms about four months ago, I was wondering if anyone had an idea as to what would mimic the thunk previously created by the one very bad control arm.
I seem to remember reading something about the front Sway Bar bushing causing this kind of problem.
Any help or thoughts would be greatly appreciated.
Old 05-29-2013, 09:39 PM   #4 (permalink)
Carmine's Avatar
2014 Santa Fe Sport 2.0T AWD w/ Tech Package
Carmine is an unknown quantity at this point
Originally Posted by wcw1 View Post
Hi v33sonata
You got it. Sway bar links. They'll make a nice clunk if you turn the car from left to right very quickly, that'll help diag them.
Carmine is offline   Reply With Quote Quick reply to this message
Old 05-30-2013, 12:19 PM   #5 (permalink)
hmr1979's Avatar
2006 Sonata - 3.3 L 2006 Azera Ultimate
hmr1979 is an unknown quantity at this point
What exactly is your noise - my upper control arm bushings did more "creaking" rather han distinct clunks.
How old is your strut mount and strut assembly?
hmr1979 is offline   Reply With Quote Quick reply to this message
Old 05-30-2013, 12:30 PM   #6 (permalink)
v33sonata's Avatar
Its most likely lowers then. lowers clunk specially when stopping or accelerating
Old 05-30-2013, 02:32 PM   #7 (permalink)
Drives2003 BMW M5 Drives 2006 hyundai Sonata gls (2.4)
jdmstr22 is an unknown quantity at this point
it sounds like its most likely your strut mounts. Do a quick visual of both and take a 14mm wrench to the top nut like your going to tighten the strut does it move around easy? is the strut off center? but sounds like a bad mount to me...
jdmstr22 is offline   Reply With Quote Quick reply to this message
Old 05-30-2013, 05:59 PM   #8 (permalink)
wcw1
Everything is original except for the upper control arms (63000 miles). The noise is thunk or clunk only noticeable when going slow and over a bump like a speed bump in a parking lot.
Old 05-30-2013, 06:27 PM   #9 (permalink)
wcw1
Like I said , I only hear the noise when going slow over a speed bump. Too much road noise when going fast to hear it. So far, I have one of each of the front end parts to check.
WCW
Old 05-30-2013, 06:48 PM   #10 (permalink)
WCW
yeah... its most likely your strut mounts as i mentioned before control arm bushings will make more of a creaking noise.
