LinkBack | Thread Tools |
#1 (permalink) |
Yesterday I noticed a slight clacking noise coming from the engine, but it was only when I was just barely on the gas. It wasn't there at idle. Now today after an hour drive, it is loud, and at all rpm's.
What could it be? I'm worried... |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Drives 07 NF Sonata V6
What engine what year if its a 4 is it auto or manual? Is it a sonata?
07 V6 NF Upper an lower billet grille 6k lowbeam n foglight HIDS Chrome stock wheel skins Added factory spoiler Kenwood DDX-419 double din head unit painted inside headlights more to come
#4 (permalink) |
Its a 4cyl 2006 Sonata. Sound is coming from the engine, not sure from where yet, sounds like metal clacking on metal, it's bad enough that I don't want to turn it on anymore.
The weird thing is that there is no loss of power, engine temps are normal, nothing visibly leaking. |
#5 (permalink) |
Tow it..
We starting to see tensioner and rail extend to point that chain is loose and flopping, and the chain cuts into the oil jet tube that streams oil onto crankshaft cog and chain.. I just did 1 not quite a month ago, neighbor did 1 a couple month ago.. Dont let the chain jump, or it trash the engine.. ours jumped, but not far enough to crash chain 2 rails tensioner oil jet front crank seal tube of goo valve cover gasket oil oil filter consider replace drive belt if aged when going back together
<--- please fill in the 'location' and 'what you drive' boxes on your personal profile page. This information makes it much easier for other members to answer/comment on your posts. |
#6 (permalink) |
Yeah, I'll have it towed. I was thinking maybe the chain or something, cause the car is running just fine. Idle is good, just the noise, it's really bad.
How much more can I expect to pay at the dealership than at a mechanic? This isn't something I'm confident doing by myself, I've messed up a timing belt before... |
#7 (permalink) |
2007 Sonata GLS 2.4 manual
Make sure to update with their diagnosis.
I had a similar noise once and it was the oil filter. As we all know, Hyundai has a TSB warning that aftermarket oil filters can cause a knock. Going back to a dealer filter fixed it for me.
I'm the dissatisfied owner of an unreliable 2007 Sonata GLS. Last edited by stephen9666; 02-04-2013 at 12:30 PM. |
#8 (permalink) |
Noise is coming from inside the engine. Mechanic thinks it's a wrist pin. So basically they said I need a new motor. Can get a used one for $2-3k plus delivery and install it comes out to be about $4,700. I didn't pay much more than that for the car, so I may just be getting rid of it. Maybe my wife will get that minivan she's been wanting...
#9 (permalink) |
The oil filter issue does cause a knocking form inside the engine. In my case, it was knocking so bad I was sure the engine was shot. A new filter fixed it.
I'm not saying the diagnosis is wrong. They very well could be right. But, since filters are a known issue on this car it might be worth a shot. Is this a dealer or independent shop you took it to?
I'm the dissatisfied owner of an unreliable 2007 Sonata GLS. Last edited by stephen9666; 02-04-2013 at 03:44 PM. |
#10 (permalink) | |
2003 2.7 Santa Fe
2001 3.0 Z3
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
