Bought an 09 limited v6(need fluids replaced) - Hyundai Forums : Hyundai Forum
Old 01-03-2013, 10:58 PM   #1 (permalink)
Drives 2009 Hyundai Sonata v6
FormulaDrift is an unknown quantity at this point
Default Bought an 09 limited v6(need fluids replaced)
I just bought a 2009 sonata limited v6 with the navi package about 2 weeks ago. It has 88k on it and I think its overdue in some maintenence.
I changed the oil and oil filter and the engine air filter.
Has new tires too.
Guys have any recommendations on what to do now?
i'm thinking the following:
1. Transmission fluid Flush and replace
2. Power steering replacement
3. Coolant replacement.
4. Brake fluid
5. cabin air filter
6. Spark plugs
7. fuel filter
any input would help, Thanks guys.
-John
FormulaDrift is offline   Reply With Quote
Old 01-04-2013, 12:43 PM   #2 (permalink)
Sonata NF
mgsgunny is an unknown quantity at this point
Take a look at my thread,
Definitely, I would say do not try to do the PSF "Flush" yourself, unless you just use a turkey baster very patiently little by little.
Transmission Fluid Change, theres a pdf out there somewhere I just cant find it on google right now.
Air Filter, and cabin air filter, see manual
IDK about the other stuff.
mgsgunny is offline   Reply With Quote
Old 01-04-2013, 01:07 PM   #3 (permalink)
hmr1979's Avatar
2006 Sonata - 3.3 L 2006 Azera Ultimate
hmr1979 is an unknown quantity at this point
Has new tires too.
4. Brake fluid
5. cabin air filter
6. Spark plugs
7. fuel filter
-John
Tons of threads on this forums about scheduled maintenance in accordance to mileage.
At 88k miles I would ATF fluid exchange, you can do it yourself.
Do you have records of maintenance done to the car thus far..this would help out.
Spark plugs at 100k
Don't touch fuel filter
Cabin air filter - get on ebay
Coolant dependent if it has been done at 50k - I do mine every 50k
I'd check brake pads n rotors before I would worry about bleeding it.
my .02
hmr1979 is offline   Reply With Quote
Old 01-04-2013, 01:30 PM   #4 (permalink)
Well I have very little experience in doing maintenence and powertrain work. I'm afraid i'll screw up the car if I Do it myself.
So I'm gonna take it to get the ATF flushed and exchanged and same with Power Steering. I figured i might as well take it to hyundai and keep the fluids OEM.
as for the spark plugs, and cabin filter and coolant, i'll do myself.
Old 01-04-2013, 03:58 PM   #5 (permalink)
hmr1979's Avatar
You Weill do the spark plugs yourself? Looks like you have a v6 from your info. V6 spark plug replacement is not easy if you were honest in saying you weren't comfortable doing a transmission fluid exchange. Its much much harder.
Old 01-04-2013, 04:03 PM   #6 (permalink)
Drives '06 Sonata LX Also '08 Ford Taurus
kn5owa
Spend a little more money - get a new battery - winter is coming
kn5owa is offline   Reply With Quote
Old 01-06-2013, 12:15 PM   #7 (permalink)
2007 Sonata GLS 2.4 manual
stephen9666 is an unknown quantity at this point
My Sonata's cabin air filter was incredibly dirty when I replaced it at 60k miles. I don't know if it had ever been changed. It's pretty easy to do.
I had the dealer change the brake fluid, since you need to actuate the ABS pump to do it properly. I think it cost $79.
I changed the manual tranny fluid myself using genuine Hyundai fluid. The fluid was $17/quart. The OP has an automatic, so I would probably recommend the dealer, so you'll be getting OE fluid, although it's not critical to have the dealer do it.
I have yet to do the coolant. I bought a gallon of Hyundai fluid from the dealer for $20.
I'm the dissatisfied owner of an unreliable 2007 Sonata GLS.
stephen9666 is offline   Reply With Quote
Old 01-06-2013, 01:13 PM   #8 (permalink)
kn5owa
Query: lots of people interested in changing p.s. fluid lately.
Do people still use atf fluid for the p.s.?? Use to be the thing to do.
Old 01-07-2013, 02:02 AM   #9 (permalink)
kn50wa, I just bought a New battery from hyundai a week ago.
Well I still need the Tranny fluid replaced. Dealer wants $220 to flush and replace...
thats pretty **** expensive for a tranny fluid flush no?
I wanna install HID xenons too maybe 5000k.
Old 01-07-2013, 04:04 PM   #10 (permalink)
Estlander's Avatar
2009 Sonata GLS 2.4L
Estlander
I'd say so! Just had my tranny fluid changed(flushed) at a local Hyundai dealership and it cost me $155. Coolant flush was $120.
Estlander is offline   Reply With Quote
