tire pressure warning light - Hyundai Forums : Hyundai Forum
Old 11-24-2012, 01:50 PM   #1 (permalink)
Drives Sonata
corbetes1 is an unknown quantity at this point
Default tire pressure warning light
The tire pressure warning light came on about a week after the tires were rotated (and I assume filled) at the dealer. My son in law checked all 4 tires and they were above 30. Didn't want to fill anymore since I have the green caps. Light is still on. Is it safe to drive on highway at 75/80 mph? HOw does this light determine low pressure. Why is it still on?
No other problem so hate to go to dealer for this but would like the light to go out.
corbetes1 is offline   Reply With Quote Quick reply to this message
Old 11-24-2012, 02:33 PM   #2 (permalink)
Dennis the Mennis's Avatar
'Splain, please.
Old 11-24-2012, 02:44 PM   #3 (permalink)
ActionMan's Avatar
Green caps are used to denote when nitrogen is used instead of regular air.
Vehicles Owned:
  • 2009 Hyundai Sonata GLS
  • 2001 Saturn L200
  • 1986 Saab 900 Turbo
  • 1979 Datsun 210
  • 1973 Mercury Montego
ActionMan is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 12:31 PM   #4 (permalink)
hoby2hq2's Avatar
2011 Sonata 2.0T Limited
hoby2hq2 is an unknown quantity at this point
Green = nitrogen filled tires. You can add regular air to the tire still (normal air is mostly nitrogen anyway). Should be no problem to go up to 34-35 psi. The light should turn off unless there is a problem with a sensor...
Old Garage: 2009 Sonata 2.4; 1999 Grand Cherokee 4.0; 1999 300m 3.5; 1994 Firebird 3.4; 1995 Beretta 2.2; 1989 Grand AM 2.5
hoby2hq2 is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 01:43 PM   #5 (permalink)
Is it the low air indicator,,,, or the actual yellow letters "TPMS" ?
Dont mean a thing, system will also be looking for hi/low spread too,, how much above 30 ?
So,, air we breath is 78% nitrogen,, inflate the tires to 35/36 and drive, see if low air light go out after a mile or so
Light is still on.
See above,, which light is illuminated ?
How much air is in the tires above 30 ? I prefer 36 in my own tires and drive 75 all the time on the interstate. In most respects, TPMS is of no real concern for driving, unless sensor has is actually providing valid info to module with a low pressure input below threshold value, or the module or wiring is on the fritz.. you got even air in all 4 tire above 32, low air light should go out.
IF "TPMS" is illuminated, then visit to Hyundai be in order to recover fault code and determine where the actual fault is.
Sensor inside each tire (mounted to wheel via stem) is sending infor to the TPMS module, consisting of module ID, temperature inside tire, pressure inside tire, and a few other tid bits of info.. the module looks at the data, and if there is excessive pressure spread between high and low, then module will turn on the low air light, which will prompt you to hopefully investigate the current situation with tire pressure gauge and find the low tire and correct the situation, be it normal air loss over time/temperature swing with marginal air to start with, or a puncture of tire needing repaired to hold air again
Why is it still on?
Which light is illumated ?
If it the yellow "TPMS".... you going to visit dealer to find which part of overall system is at fault...
Low air indiactor,,, put 35/36 in the tires and see what happen
NOTE-- yellow not show well on this back ground, so different color used --
(!) symbol = find the low tire, correct the air in the tires
TPMS = scan me for fault code, circuit fault some where, code will reveal which circuit at fault
Old 12-14-2012, 12:29 AM   #6 (permalink)
peacefrog_0521's Avatar
2008 Sonata GLS 2.4L 4cyl
peacefrog_0521
You might have to bite the bullet and go to the dealer unless the place that filled your tires can scan the sensors, which I doubt. I filled up my tires back in August and shortly after my TPMS light came on; I rechecked and all four were at 37 PSI. Dealer found that one of the sensors somehow was sending "all zeroes", basically a null signal. They were able to reset it and it has been OK since. 1/2-hour labor charged.
peacefrog_0521 is offline   Reply With Quote Quick reply to this message
