Replacing the battery - Hyundai Forums : Hyundai Forum
Old 11-17-2012, 08:53 AM   #1 (permalink)
06sonata
Fdup is an unknown quantity at this point
Default Replacing the battery
Does anyone know if after replacing the battery, you have to reset codes, or something like that I keep reading that on other websites, but nothing specific for the sonata.
Fdup is offline   Reply With Quote Quick reply to this message
Old 11-17-2012, 09:21 AM   #2 (permalink)
Elantra UD
Swordfish1978ca is an unknown quantity at this point
what codes do u mean, there are no resets needed for the sonata.
Swordfish1978ca is offline   Reply With Quote Quick reply to this message
Old 11-17-2012, 10:22 AM   #3 (permalink)
Drives 09 Sonata Limited V6
tms0633 is an unknown quantity at this point
Hi,
When I replace a a battery, I clip a float charger to the battery cables. The small amount of current holds your radio presets and security codes.
tms0633 is offline   Reply With Quote Quick reply to this message
Old 11-17-2012, 10:31 AM   #4 (permalink)
Drives '06 Sonata LX Also '08 Ford Taurus
kn5owa
You have to reset the radio and clock unless you use a memory saver - and those gadgets may or may not work. I don't recommend them.
More importantly, on the '06, there is a heat shield around the old battery - make sure you re-use it - the conventional wisdom is that summer heat is what demolishes car batteries.
kn5owa is offline   Reply With Quote Quick reply to this message
Old 11-17-2012, 03:18 PM   #5 (permalink)
Negative 1's Avatar
I have a 2008. When I replaced the battery, I had it disconnected (i.e. without any battery) for hours. When I installed the new battery, all the radio stations were still as they were. I think I had to reconfigure the equalizer settings (and balance/fader/etc. settings, if other than default). I definitely had to reconfigure the clock. That's it, though.
Negative 1 is offline   Reply With Quote Quick reply to this message
