LinkBack | Thread Tools |
#1 (permalink) |
2010 Sonata SE & 2011 Kia Sorento EX V6 AWD
Searched around here but couldn't find a solid answer to my questions.
My '10 2.4 Sonata recently rolled over 100K (60mi). The tranny fluid change is something I am looking to get done at my shop this week. I just want to know what you guys recommend. So far it seems the Valvoline MaxLife Dex/Merc seems to be the stuff I am planning to put in. I need to know how much fluid this thing takes. I am only doing a drain and fill. Any other things I should know feel free to post! Thanks |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
2006 sonata, 4 cyl
Dont forget the gasket from the dealer for the drain plug. When I got my car at 89,000 the fluid had just been changed. I then drain n filled myself with Castrol Import Multi Vehicle at 100k, I added 4 qts of new fluid.
It shift perfectly now, even better than before. |
#4 (permalink) | ||
#5 (permalink) | |
2006 Sonata - 3.3 L
2006 Azera Ultimate
#6 (permalink) | |
I work at a fairly large repair shop/dealership and they also recommended me to not to do a flush. |
#7 (permalink) | |
2006 Sonata - 3.3 L
2006 Azera Ultimate
If it works drain and refill, that is definitely a lot cheaper. |
#8 (permalink) |
Replaced the fluid today. Put 4 1/2 quarts of Valvoline Maxlife Dex/Merc in it. What came out of the tranny had 103,000Kms (61,000Miles) on it. It was pretty black. Car shifts like new again!
#9 (permalink) |
06 Sonata F24S of course.
GL was correct in only doing a drain and refill on his car. Sounds like this was the 1st change after 61,000 miles and the fluid being black. I've seen flushes "clean" the trans to the point a failure happens because "stuff" was flushed off.
Flushes are good, and I do them on mine, but only at the specified intervals. I flushed mine at 30,000 miles and will probably just do a drain and refill at 60k. Here is a thread from 07 regarding trans fluid and changes....quite the interesting read. http://www.hyundai-forums.com/181-nf-2006-2010-sonata/82527-tranny-fluid.html |
#10 (permalink) |
Drives Sonata se
Drives caravan
Drives chevy uplander
Ive been working in trans shops for years and the best thing you can do is replace your trans fluid anytime it starts breaking down.
This will happen faster when driving a lot of short trips at low speeds because the converter hardly ever gets a chance to go into lockup. No lockup means high trans fluid temps. Also use Hyundai trans fluid or synthetic fluid only. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
