high brake light bulb replacement - Hyundai Forums : Hyundai Forum
Old 11-03-2012, 07:44 PM   #1 (permalink)
cmerica's Avatar
cmerica
Default high brake light bulb replacement
After losing 4 bulbs trying to put the new light in from the bottom on my 07 Sonata's high brake light, I finally figured out, that if you take a dremel or other small cutting tool and cut of the tab on the bulb socket, the whole assembly will slide back into place from the top. Cut the tab even with the holes where the two wires go into the socket, and you should have no problems.
cmerica is offline   Reply With Quote
Old 11-03-2012, 10:42 PM   #2 (permalink)
craigbrooks's Avatar
06 Sonata F24S of course.
craigbrooks is an unknown quantity at this point
Replace High Mounted Rear Stop Light?
craigbrooks is offline   Reply With Quote
Old 11-03-2012, 11:06 PM   #3 (permalink)
GLSonata's Avatar
2010 Sonata SE & 2011 Kia Sorento EX V6 AWD
GLSonata is an unknown quantity at this point
I have never cussed at such a stupid design in my life
GLSonata is offline   Reply With Quote
Old 11-12-2012, 03:51 PM   #4 (permalink)
hmr1979's Avatar
2006 Sonata - 3.3 L 2006 Azera Ultimate
hmr1979 is an unknown quantity at this point
lol I finallllly changed mine over the weekend....it is by far the oddest design on this car...seems like every other bulb has a relatively easy access...except this one. My guess is they changed this on the YF?
Oh yeah...I did scratch my tint a little bit with the light housing on the inside
hmr1979 is offline   Reply With Quote
Old 11-12-2012, 03:56 PM   #5 (permalink)
GLSonata's Avatar
I don't understand why they did it the way they did. It's like they made a mistake on the design and just never fixed it. I don't see why they couldn't of just cut the hole out a few inches over.
I see waaay too many Sonatas on the road with that bulb burnt out. I guess the factory bulb is garbage or the circuit is high voltage. I contemplated putting an LED bulb in there at one point since they seem to last longer but (knock on wood) mine has been good since I replaced it last year.
Old 11-12-2012, 04:06 PM   #6 (permalink)
hmr1979's Avatar
I'm not sure if the brake light switch is associated with the high mount bulb going out...but these two items are almost inevitable for these cars.
Old 11-12-2012, 06:32 PM   #7 (permalink)
Drives '06 Sonata LX Also '08 Ford Taurus
kn5owa
I've has good luck with Sylvania long life LL bulbs (so far) -- Buy 'em at Autozone
kn5owa is offline   Reply With Quote
Old 11-15-2012, 11:17 PM   #8 (permalink)
vinniecap's Avatar
2013 Elantra GT 2008 Sonata SE V6
vinniecap
HMR...that's a good question about the brake light switch.
I had my ECS light going on and off for awhile now. Finally got it fixed at the dealer yesterday, while the car was in for a TSB regarding the TPS Sensor. When they called to tell me the car was ready, they also said the 3rd brake light bulb was burnt out. I think he said it was something like 65 bucks to replace. I will be replacing that myself. Any tips to make things easier?
vinniecap is offline   Reply With Quote
Old 11-15-2012, 11:39 PM   #9 (permalink)
GLSonata's Avatar
And dealerships wonder why they get called 'Stealerships'. Thats daytime robery.
Old 11-16-2012, 08:08 AM   #10 (permalink)
vinniecap's Avatar
vinniecap
Tell me about it. I laughed at the service manager when he told me the price. It's bad enough it cost me 325 for a TPS sensor and Brake Light switch. 2 items I could have done myself. Only reason I couldn't is because the TPS sensor repair requires an update to the ECM software. I suppose I could have done the brake light switch, but the part was 40, and total with install was 70. So I figured what the ****, i'm already getting screwed!
