Transmission oil sp3 alternative - Hyundai Forums : Hyundai Forum
Old 10-27-2012, 08:59 AM   #1 (permalink)
jp149
Default Transmission oil sp3 alternative
For any of you that are looking into changing your tranny fluid for your car I strongly recommend valvoline maxlife trans oil. Not only is it $23 at Walmart in canada for a 5litre jug its shifts very quickly and smoothly seems to have the new car feeling again. Amazing fluid I also use it in my mitsu with the same results.
Valvoline.com > Products > MaxLife > Automatic Transmission Fluid MaxLife > MaxLife® DEX/MERC ATF
jp149 is offline   Reply With Quote Quick reply to this message
Old 10-27-2012, 02:17 PM   #2 (permalink)
Drives 07 Sonata GLS 2.4 13 Sonata GLS 2.4
Partner is an unknown quantity at this point
Are you serious about putting DEX/MERC ATF in a hyundai?
Partner is offline   Reply With Quote Quick reply to this message
Old 10-27-2012, 02:59 PM   #3 (permalink)
ActionMan's Avatar
Well it does say that it meets SP-III requirements:
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
Vehicles Owned:
  • 2009 Hyundai Sonata GLS
  • 2001 Saturn L200
  • 1986 Saab 900 Turbo
  • 1979 Datsun 210
  • 1973 Mercury Montego
ActionMan is offline   Reply With Quote Quick reply to this message
Old 10-27-2012, 04:07 PM   #4 (permalink)
It says "Recommended for use"... nothing that it is SP-III spec.
You find most will say "compatable with"... but it is not made to SP-III specifications as called by Hyundai-Kia..
Ask Valvoline if you can use that stuff in an EQUUS or Genisis automatic transmission ..
Old 10-27-2012, 05:14 PM   #5 (permalink)
ActionMan's Avatar
You are correct, however why would they recommend this ATF for use in transmissions which require SP-III unless it meet those specifications? It would seem that they would only be opening themselves up for lawsuits if this ATF did not in fact meet those specifications.
Vehicles Owned:
  • 2001 Saturn L200
  • 1979 Datsun 210
Old 10-27-2012, 06:58 PM   #6 (permalink)
jp149
Use it or don't use it, its up to you. if you want to buy that overpriced OEM fluid for piece of mind go ahead, I've already put my money where my mouth is and have 2 trannys on this fluid. IMHO the oem fluid isn't as good as the vavoline.
See section 8
http://www.valvoline.com/faqs/system...mission-fluid/
Old 10-28-2012, 01:19 PM   #7 (permalink)
2009 Hyundai Sonata GL 2.4L 2009 Hyundai Sonata LTD 2.4L
marthinus is an unknown quantity at this point
I have used Valvoline Maxlife ATF now twice in my 2009 Sonata tranny with no problems. During my second fill , I installed a Magnefine inline filter on the return line to the tranny.
marthinus is offline   Reply With Quote Quick reply to this message
Old 10-29-2012, 08:47 PM   #8 (permalink)
PostalBound
Yep, I've used it in 2007 sonata and also used the multi-import sp3 compatible Supertech fluid with good results. Pushing 200k miles on the 07 sonata limited. Both worked well.
PostalBound is offline   Reply With Quote Quick reply to this message
Old 10-30-2012, 01:22 PM   #9 (permalink)
riceR's Avatar
09 Sonata 3.3, 06 Saab 9-3 Aero
riceR is an unknown quantity at this point
Quite honestly, anything with the SP-III spec is much better than the OEM stuff... Like others, I've used the Castrol Multi Vehicle ATF and it works much better so I wouldn't doubt the Valvoline stuff to be better than OEM. Once I hit ~90k I'll do another drain fill with Wolf's Head Super Universal ATF since I have 6 quarts left over from doing the Saab. The compatibility list on the Wolf's head is redonkulous.
Mods
riceR is online now   Reply With Quote Quick reply to this message
Old 10-30-2012, 05:40 PM   #10 (permalink)
"Canada's DuraDrive™ MV Synthetic ATF offers true multi-vehicle performance, outstanding wear protection, and exceptional fluid life. DuraDrive MV Synthetic provides the frictional properties, wear protection and viscometrics needed by most major North American, Asian, and European automatic transmissions."
This ATF I will used next time. SP-3 compatible too.
