Instrument Cluster Troubleshooting - Hyundai Forums : Hyundai Forum
Old 06-27-2012, 12:17 PM   #1 (permalink)
Drives a 2006 Sonata 3.3 NF
cgp2 is an unknown quantity at this point
Default Instrument Cluster Troubleshooting
2006 Sonata 3.3 (NF series)
A few days ago the instrument cluster and LCD odometer stopped working. The dash cluster lights up, warning lights flash on at start up just no indication of speed, fuel level, tach, or temp.
Fuse is good & has power to it. I re-seated all the connectors under the dash. No luck.
Anybody heard of this?
cgp2 is offline   Reply With Quote
Old 06-27-2012, 01:09 PM   #2 (permalink)
Supernova88642's Avatar
2007 NF Sonata I4
Supernova88642
Try taking out the cluster unplugging the wires and reinstalling it. Worth a shot
http://www.amdmaddness.com/sonata/ts...er_removal.pdf
Supernova88642 is online now   Reply With Quote
Old 06-27-2012, 09:26 PM   #3 (permalink)
AGW
2006 NF Sonata V6
AGW is an unknown quantity at this point
Here is a thought. I had a BMW do the same thing. No speedometer. It was the ABS sensor. There is a speed sensor & also might check the 10 amp fuse for the cluster.
Hope it helps.
Cheers!
AGW is offline   Reply With Quote
