Check Engine Radiator Fan issue - Hyundai Forums : Hyundai Forum
Old 02-26-2012, 04:29 PM   #1 (permalink)
Drives Sonata LX
WilDevine is an unknown quantity at this point
Default Check Engine Radiator Fan issue
I have a check engine light on. 2006 Sonata. Ran the diagnostics. It's the radiator fan. I put power directly to the fan and it works. I'm thinking that the relay might be bad. I checked the fuse to the relay and it's fine.
1. Would a bad relay cause the check engine light to come on?
2. Where is the relay?
I looked in the relay/fuse box under the hood and the fuse box near the steering column inside the car. Can't determine if the relay for the fan is one of the ones in the relay box under the hood or not.
Also, I can't get the engine temp past the half way mark. My other question would be --> At what point should the radiator fan come on?
Thanks much for your help.
WilDevine is offline   Reply With Quote Quick reply to this message
Old 02-26-2012, 07:23 PM   #2 (permalink)
gotv33's Avatar
2006 Sonata NF V6 GLS ....... paid off.........finally!!!!
gotv33 is an unknown quantity at this point
I have the same issue. I was told by the Hyundai service dept that I needed to replace the engine control fan module. I ordered one which should arrive later on this week. I will post the results once installed.
BTRcc | Custom CAI | D2 Racing RS Coilovers | 3.8 GenCoupe OBX Pulley | 1g Eclipse Front Upper Strut Bar | Low's & Fog's HID 6000k | Projector Fog Lights | V-LEDS | Ixion Grill | XXR 530 18x9.75+20
gotv33 is offline   Reply With Quote Quick reply to this message
Old 02-27-2012, 03:24 PM   #3 (permalink)
gotv33's Avatar
Just got the replacement control module today. Will install tomorrow and see what happens.
