Air Bag Warning Light Is Intermittent - Page 2 - Hyundai Forums : Hyundai Forum
Old 08-06-2011, 08:02 PM   #11 (permalink)
Supernova88642's Avatar
2007 NF Sonata I4
Supernova88642
My airbag light went on last night and its not going back off now oh boy its werid the passanger airbag off light is not lit up even when there isnt someone sitting in the seat, i can already tell this is going to be fun,
Supernova88642 is offline   Reply With Quote Quick reply to this message
Old 08-07-2011, 02:08 PM   #12 (permalink)
2007 NF Sonata I4
Supernova88642
I unbolted my passenger seat today and unplugged all the wires underneath and reconnected it hoping it would solve my problem well it didnít so next i took out my speed cluster and i took out the light bulb for the airbag light and reconnected everything and there ya go problem is somewhat solved out of sight out of mind...
Old 08-08-2011, 11:39 AM   #13 (permalink)
Flotsam's Avatar
Family fleet:06 Hyundai Sonata V6, 01 VW Cabrio & 02 VW Jetta, 98 Subaru Outback (HG), 95 BMW 325i
Flotsam
Thanks for the pics SBR. Just curious how the OCS mat is supposed to work and what the failure mechanism is?
If that's it I am just curious what purpose it serves since I thought the issue was small children/infants sitting in the front seat and having the airbag deploy. We have none of those (small children/infant) in our family so to spend $900 (assuming that was it) is a non-starter. And especially armed with this information it sounds like a design defect from the start, maybe warrants a good discussion with the Hyundai zone rep.
Flotsam is offline   Reply With Quote Quick reply to this message
Old 08-08-2011, 04:49 PM   #14 (permalink)
ElkScout
Have the same stupid passenger seat issue on my 06 LX. Quoted like $1500 or something ridiculous! We just ignore the light, but I may consider pulling the bulb sometime in the future. We have 90,000 miles on ours and were second owners so it would be our dime... which it won't be. Grrr! Problem started around 83,000 I think.
Good luck with yours! Between the insanely expensive seat cushion issue and the slowest gear hunting of an automatic that I've ever experienced, I'm not a loyal hyundai enthusiast anymore.
2006 Hyundai Sonata LX in white with chrome OEM wheels
ElkScout is offline   Reply With Quote Quick reply to this message
Old 08-08-2011, 09:42 PM   #15 (permalink)
2007 NF Sonata I4
Supernova88642
It took me longer to unbolt the seat and play with the wires then it did to take out the light bulb I had the light out and everything reconnected in about 15 min
Old 08-17-2011, 06:49 PM   #16 (permalink)
tonyk11
This is exactly what I'm thinking. I want to simply reconnect the stupid light to another light. You can't even get an inspection in VA with an airbag light on, so on a car that is virtually perfect, I have to pay $1300 to fix a feature I don't even use just to get an inspection.
I think Hyundai should pay for this for every car made during that year. My Sonata falls in the recall years, but they won't pay for it because my VIN isn't included in the recall. Bunch of crap if you ask me.
Will be removing the cluster later this evening....
tonyk11 is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 01:54 PM   #17 (permalink)
jagnorb
my Nissan Frontier had that issue when you messed with the electrical system without first removing the neg lead from the battery. The fix was to turn the key off and on 5 times.
jagnorb is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 05:17 PM   #18 (permalink)
dhealy50
my Snap-on scanner reads the airbag codes, and gives information on the DTC's. It can also be used to reset the system. My problem is with the drivers seat belt. Resistance High.
dhealy50 is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 11:15 PM   #19 (permalink)
QUOTE (ican @ Aug 22 2011, 05:17 PM)
Re-read the description slowly and carefully.. is it "belt pre-tension",,, or "buckle pre-tension",, or "buckle switch".....
Be nicer if you post the code as recovered from scan... has more value.
I have popped the exploders on some (7) buckle pre-tensioner here in the last couple days.. do that before disposal, as you not supposed to dispose of SRS parts with live exploders intact..
Gots 4 or 5 DAB modules here, but hate to waste those... thems some big $$$$$ items
Old 09-11-2011, 12:12 PM   #20 (permalink)
stray
i have the airbag light on (not pass side) again, and this time the dealer is saying it's because the driver's side seat belt buckle is bad. he also is telling us that hyundai won't cover it under my 10/100 extended service warranty, car has around 78K. the first time it happened was when the crankshaft pulley came apart and they said it was due to the alternator not putting out full power when the belt slipped. next time i think it was the brake pedal switch. i'll be stopping in to see them on monday...
stray is offline   Reply With Quote Quick reply to this message
