Window Switch Replacement? - Hyundai Forums : Hyundai Forum
Old 07-05-2011, 12:47 PM   #1 (permalink)
Drives 2012 Sonata Limited Turbo
error666 is an unknown quantity at this point
I need some help.
My rear window is not going up using the driver switch. It is working fine if using a rear door switch but only goes down if using the driver door switch.
So I think I should replace the switch. Before I order a new one, can anybody tell me
Is there anything else that I should check or it's definitely the switch?
How do I get to it? What's the easiest way to take it off? I tried searching on HMAservice but it doesn't look like there are instructions for replacing it. I've never taken these doors apart, so I don't really know where to begin.
PLEASE HELP
error666 is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 07:38 AM   #2 (permalink)
AGW
2006 NF Sonata V6
AGW is an unknown quantity at this point
Not sure how skill you are w/ a multi meter but the removal proceedure is:
1) remove tweeter, there is a clip, with a upholstry tool or plastic putty knife it comes off easily.
2) remove small plastic covers, there are 4 including handle
3) remove screws, remember there are 2 at the bottem and @ both handles.
4) using a upholstry tool pry @ the panel, has plastic clips
5) the switches are held in as 1 peice with screws
You will need to replace all switches as is 1 peice. I think the dealership charge me around $100.00
I may have a spare due to replacing damaged handle the switches are new.
Let me know if I can help.
Cheers!
AGW is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 08:53 PM   #3 (permalink)
Thanks,
I ordered the part today and in the evening when I drove home from work it started working again. I can't believe it. Now I actually want it to break cause I have a part coming
Old 07-07-2011, 09:15 AM   #4 (permalink)
AGW
2006 NF Sonata V6
Sound like theres some dirt or dust between the contacts.
Maybe some compressed air would clear it out.
Cheers!
