Clicking Noise When Turning - Hyundai Forums : Hyundai Forum
Old 03-31-2011, 09:14 PM   #1 (permalink)
mariojas
Hi guys, I have a little problem that's starting to occur this past week and I want to get some advice before going to the dealer.
When I accelerate from stop the left wheel it like makes a "clicking" noise as the car starts accelerating, once in motion there is no "clicking"
Any ideas what might cause it?
mariojas is offline   Reply With Quote Quick reply to this message
Old 04-01-2011, 09:14 AM   #2 (permalink)
Luxury's Avatar
Luxury
A bad CV joint can make a clicking noise under load, especially when making sharp turns.
Luxury is offline   Reply With Quote Quick reply to this message
Old 04-01-2011, 09:37 AM   #3 (permalink)
mariojas
QUOTE (Luxury @ Apr 1 2011, 09:14 AM)
Yea that's what I thought at first.. I'll take a look at it today, maybe it just needs some lubrication.. and if not and it needs to be replaced... sucks that I'm not the original owner of the car(warranty)
any tips with what should i lubricate it?
Old 04-01-2011, 09:48 AM   #4 (permalink)
ADMINISTRATOR
Montego's Avatar
you will very likely be wasting your time trying to lubricate it, best just go for a new one
to lubricate the joint you will need to jack the car up, remove the clip from each end of the rubber boot that covers the c.v. joint, pull the boot back along the drive shaft to expose the c.v. joint and then pack the joint and the inside of the boot with lith molly grease (or similar) then re-fit the boot with new clips.
its a very dirty messy job and probably won't make any difference
MONTEGO
Old 04-02-2011, 01:41 AM   #5 (permalink)
2006 Sonata V6 GLS - was mine, but now my moms.
Byron007 is an unknown quantity at this point
How many miles? I have an 06 Sonata GLS V6 in FL. I have 110k now, but I discovered a slight cut in my left CV boot. I'm going to try to seal with "The Right Stuff." I'm not sure if it will work, but well worth a try.
<<<<Update your vehicle here so others know what you drive when you post. Makes it easier to help you if you have a problem. http://www.hyundai-forums.com/profil...do=editprofile
Byron007 is offline   Reply With Quote Quick reply to this message
Old 04-02-2011, 10:20 AM   #6 (permalink)
Luxury's Avatar
Luxury
QUOTE (Montego @ Apr 1 2011, 07:48 AM)
I agree. If it's already making noise, it's too late for lube.
Old 04-02-2011, 10:58 AM   #7 (permalink)
mariojas
its only 48000 miles, and that's what worries me... also it sucks the 5 year warranty expired 2 months ago and I'm not the original owner of the car.
