Tricks To Changing Out The 3rd Brake Bulb? - Hyundai Forums : Hyundai Forum
Old 05-25-2010, 02:08 PM   #1 (permalink)
jazzhands
Boy that thing is hard to get to..
has anybody any tips on how the techs do it @ your local dealer?
I'm OK with remove panels but with my large mitts its very hard to change it out going through the trunk side..
Thanks In advance!
JH
jazzhands is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 05:32 PM   #2 (permalink)
craigbrooks's Avatar
06 Sonata F24S of course. 01 Mustang GT convertible as well.
craigbrooks is an unknown quantity at this point
There is a very good thread floating around here that talks about this. I have the page saved at home and when I get there I will paste the link for you.
craigbrooks is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 08:10 PM   #3 (permalink)
downhiller88's Avatar
downhiller88
the funny thing, my dealer didnt even know how to do it...... yeah pretty pathetic so im rocking no 3rd brakes
downhiller88 is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 08:13 PM   #4 (permalink)
2006 Sonata V6 GLS - was mine, but now my moms.
Byron007 is an unknown quantity at this point
Funny but true, dealer wanted half an hour of labor to change it out, I scoffed at that idea. So, I bought an LED bulb on ebay, not one of the best but works.
Loosened the screws for the package tray, couldn't get it out....soooo I went to plan B. I took a flat head screw driver, pryed the plastic cover off breaking the clips. I got it out. I had to use a spade bit to drill a hole, and break some plastic pieces on the bulb holder to get it back in, also had to superglue the socket onto the assembly. It was a disaster.
Other's have claimed to do some deep horizon type exploration lying in the trunk and removing the third brake light. Until I see some video I don't think it can be done.
I'd just let the dealer do it and look for a high qaulity LED bulb with 360 coverage, the one I bought the LED's point up so it doesn't reflect, it lights up but not as bright as previously.
<<<<Update your vehicle here so others know what you drive when you post. Makes it easier to help you if you have a problem. http://www.hyundai-forums.com/profil...do=editprofile
Byron007 is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 08:29 PM   #5 (permalink)
2009 Sonata i4 Limited
Itchiee
QUOTE (Big B @ May 25 2010, 08:13 PM)
Oh it can be done...There are instructions here that show how.
I used them to replace mine with LEDs
http://www.hyundai-forums.com/index.php?&a...37&CID=1016
Itchiee is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 08:30 PM   #6 (permalink)
Drives 2006 Sonata GL V6 156,000 kms
rallyman
http://www.hyundai-forums.com/index.php?sh...;hl=brake+light
See post #18 in this thread. That's how I did it and it works.
rallyman is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 08:38 PM   #7 (permalink)
Amateurs....
Inside the trunk, remove the 2 screws from underneath, 1 is silver, the other is gold color... you will need to pull the hole covering from 1 side to gain access to the screw. Unplug the connector.
Go inside the cabin, start to remove the lamp,, get it up enough that you can reach in and twist the wings on the socket to release it from the lamp housing, drop the bulb and socket down out of way so you can finishe removing the lamp housing.
Grab the socket with short pigtail, replace bulb.. Take a pair of side cutter and cut them wings off at the base of the socket.
Install bulb and socket into housing, install lamp assembly back onto the deck panel
re-install the 2 screws, and plug in the connector..... all done
Word of caution, be carefull getting socket out of the lamp, co-worker cut his fingers pretty good doing 1, it was the used car fella, he not come ask for directions..
Old 05-25-2010, 09:30 PM   #8 (permalink)
QUOTE (sbr711 @ May 25 2010, 08:38 PM)
Amateurs....
Show some video I want to see this done.
Old 05-26-2010, 12:31 AM   #9 (permalink)
Gadgettime
I just recently replaced mine. I just used force to push it back in. If I was replacing it though I would just buy the LED piece on ebay for about $30 I think. It saves so much time and hassle from trying to force it in. It took me a couple hours just to try and figure out how to get the dam thing back in.
Gadgettime is offline   Reply With Quote Quick reply to this message
