Key Does Not Work On Driver's Side Door - Hyundai Forums : Hyundai Forum
Old 08-27-2008, 08:38 PM   #1 (permalink)
davidgaithers
Hello all,
I just bought a 2003 Elantra this past weekend, and am very happy with it so far.
In an attempt to bypass the alarm, I tried to use the key on the driver's side door to lock/unlock, and discovered that the key does not work on that door.
The key does work on the passenger side door. And the driver's side door can be locked/unlocked with the remote, as well as by using the lock switch button inside.
Does this sound like an expensive repair? And there will be a downside in the long run if I don't fix it?
Thanks all in advance.
-David
davidgaithers is offline   Reply With Quote Quick reply to this message
Old 08-28-2008, 02:30 PM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
this sounds like either the lock itself is broken or the lincage has come adrift inside the door, the door trim will have to come off to investigate the problem, it will not do ant harm if you leave it
MONTEGO
Old 08-28-2008, 09:00 PM   #3 (permalink)
davidgaithers
thanks, montego
Old 09-02-2008, 11:30 AM   #4 (permalink)
xx_ph4nt0m_xx's Avatar
xx_ph4nt0m_xx
Send a message via MSN to xx_ph4nt0m_xx
I have the same problem on my sonata, but its because i dont have the orginal key, it was actually made at wal-mart. It will start the car but not work on the door locks because its got one little spot the just doesnt line up right... see if the other key you have might do it if you have one that is. if not that the montego is right.
I'm not saying there should be capitol punishment for stupidity, but lets just take the warning labels off of things and let the problem fix itself...
xx_ph4nt0m_xx is offline   Reply With Quote Quick reply to this message
