Fuel Door Stuck - Hyundai Forums : Hyundai Forum
Old 03-03-2005, 01:26 PM   #1 (permalink)
rguedel
Hello,
I have a 2004 Elantra GT and my fuel door is stuck. When I release the lever from inside it does not open. Has anyone had this trouble before? I don't want to pry it open. Any suggestions. I think the little cord the gas cap is attached to must be stuck on the latch or something.
Thanks!
rguedel is offline   Reply With Quote Quick reply to this message
Old 03-04-2005, 09:08 AM   #2 (permalink)
VALKYRIE YB70's Avatar
VALKYRIE YB70 is an unknown quantity at this point
This is too difficult for most owners to fix themselves.......your car is covered by warranty, make use of it!.
Nick.
Front-mounted Intercooler with silicone pipework
Re-cycling BOV
Ecotek unit
K&N cone filter with ram + 12v. fanned cold air
Adjustable fuel pressure regulator
2.5" dia. custom cat-back stainless steel exhaust
15"x7" TSW alloys
Spax lowering springs over Pedders struts
Rear track increased by 2.5"
Alloy front strut brace
Manual boost controller running 12 p.s.i.
Upgraded cockpit with replacement 6-speaker C.D. system
My S-Coupe Turbo Slideshow :-
http://aol.photobox.co.uk/slideshow/index....?c_album=546423
VALKYRIE YB70 is offline   Reply With Quote Quick reply to this message
Old 03-16-2005, 12:01 PM   #3 (permalink)
selenico77
May be the Spring that push out the door that is week.
open the door aften unlocking with the wire ( help yourself with a toothpick).
Then (torce el metal del resorte para que haga mas fuerza).
Sorry but i donīt Know how to say that in English.
Regards
Selenico77
selenico77 is offline   Reply With Quote Quick reply to this message
Old 03-17-2005, 10:07 PM   #4 (permalink)
6g72
Send a message via AIM to 6g72
there should be a lever to pull in the trunk that opens the fuel door for emergency use, well my sonata does anyway and most cars with electric openers do. So try that if it doesn't work, take a screwdriver with a rag over the end and gently pry it so see if its just stuck, do this after pressing the relese button. Do you hear a noise when the relese button is pressed? If not, the warrenty should cover it
6g72 is offline   Reply With Quote Quick reply to this message
