buying a elantra 2002 - Hyundai Forums : Hyundai Forum
Old 09-24-2013, 09:45 AM   #1 (permalink)
magijs is an unknown quantity at this point
Default buying a elantra 2002
hi,
I'm currently living in Willemstad, Curacao and was looking for a new car. Yesterdag 1 found a Hyundai Elantra 2.0 from 2002, a white one.
So i went there to look at it and must say its a pretty nice car, looks good, drives good. Everyting works, the electric windows, he starts immidiately and it runs really nice. Also its an automatic and it shifts smoothly!!
There are only 2 things that i don't like, for 1 the ac isn't blowing cold air but i think thats a small problem and i only have to fill it up (right?)
The other thing is the mileage, currently its 235000 km so about 150000 miles and i really have no idea if thats a problem for a Elantra or not. If i drive in it, it rides very smooth but still its a lot of miles.....
I was searching the web for stories or review but i coudn't found 1 with a high mileage so i really don't know if its smart to buy this car or not
I hope you guys can give me some advice and sorry for the bad english
magijs is offline   Reply With Quote Quick reply to this message
Old 09-24-2013, 09:51 AM   #2 (permalink)
2001 Accent, 2002 Elantra
ShadeTM is an unknown quantity at this point
For the AC you need to get it checkout by a professional who can do a a vaccum test to see if there is a leak. If there is a leak it will cost you some serious money to fix it depending on the part leaking. AC is not suppose to lose the R134A unless there is a leak. They can also test for leaks using a UV dye..
For the high mileage, get a compression test done. If it is within range you should be ok. Check if the timing belt was replaced. If not you will need to replace timing belt and water pump at the same time. It is cheaper in labor cost that way.
Shade Tree Mechanic
ShadeTM is offline   Reply With Quote Quick reply to this message
Old 09-24-2013, 06:49 PM   #3 (permalink)
Em-squared's Avatar
magijs.
Fashionista.
Em-squared is offline   Reply With Quote Quick reply to this message
Old 09-25-2013, 09:01 AM   #4 (permalink)
PLP
2007 KIA Rondo, 2.7 V6, 5 A/T 2009 Hyundai Elantra, 2.0 I4, 5 M/T, sedan, GLS, black pearl
PLP is an unknown quantity at this point
could be, could not be... hard to say. It might be lack of maintenance and after years it leaked out (over ten years with no refills?)
As ShadeTM said - you might want to check it by someone who knows this stuff.
Unless, you can invest in two cans of refrigerant, or tell the seller to refill the A/C and see if it works. Sometimes it is cheaper to refill it once a year than repair some expensive parts.
It does not have to be a problem.
If it starts right away that is a good sign. If you see no huge oil leaks, oil cap looks clean (inside) and you do not smell much bad/burned from the engine - you should be good.
Also, check colour of transmission fluid.
Drive the car hard (after it reaches operating temp). See how it shifts at load, how does it accelerate under full throttle. Hit the brakes hard to see if there is no pulling to one side and so on...
Do not worry about it. You would be surprised how many people here are ESL. Me for example...
One comment here.
Water pump is not a part of TB. Sure, it is safe to replace it, but it is not necessary for the timing belt, which in turn, must be replaced, UNLESS the owner has a prove - a receipt from service stating what belt and when was installed.
Otherwise - do not even look on the belt. It always looks nice.
Compression - that is very important as it is possible that IF the timing belt was recently done it could have snapped before then causing some valves to bent (a little damage).
Therefore, compression test must be performed.
PLP is offline   Reply With Quote Quick reply to this message
