Best place to purchase Timing Belt/Water Pump/Drive Belts (05 Elantra)?? - Hyundai Forums : Hyundai Forum
Old 12-20-2011, 12:19 PM   #1 (permalink)
2005 Elantra GL
mgb_ is an unknown quantity at this point
Default Best place to purchase Timing Belt/Water Pump/Drive Belts (05 Elantra)??
I have a 2005 Elantra GL and its due for timing belt replacement. I figured I might as well do the water pump and all the other belts while Iím at it. What is the best place to order these items? Can they be purchased as a kit? I know timing belt should be OEM, what about water pump and the other belts? Any other suggestions welcomed!!
mgb_ is offline   Reply With Quote Quick reply to this message
Old 12-20-2011, 04:29 PM   #2 (permalink)
jsinton's Avatar
I'd tell you to order OEM stuff from ebay. It's pretty cheap.
Timing Belt Kit Hyundai Elantra 01 02 03 04 05 06 2.0 | eBay
Old 12-20-2011, 09:18 PM   #3 (permalink)
Behind the timing cover I would go OEM , here is a link for Forgreen on ebay for $109 plus shipping for factory timing belt water pump, gasket and idler and tensioner bearings. You would need to buy the three other belts, A/C power steering and alternator.
Timing Belt Water Pump Tensioner Idler for Elantra 2.0L | eBay
santa06 is offline   Reply With Quote Quick reply to this message
Old 12-22-2011, 09:35 PM   #4 (permalink)
Order ??? Walk into your local Hyundai dealer,, gop to the parts counter,, and leave with all the parts in hand during your lunch break... we keep all that on the shelf.
sbr711 is online now   Reply With Quote Quick reply to this message
Old 12-24-2011, 10:27 AM   #5 (permalink)
Wife drives 2003 Elantra Work vehicle 1999 Cherokee Play truck 1994 F 250 Diesel Play car 1982 Me
MS Fowler
On Hondas, its a good idea to replace the water pump when doing the timing belt, but its not necessary on the Elantra. The water pump is easily replaced w/o disturbing the timing belt.
I did the timing belt on my wife's Elantra in about 4 hours--next one would probably only take about 3 hours. Simple/ easy job.
For comparison, I attempted the timing belt/ water pump on my MIL's Civic, and gave up after a frustrating 2 hours w/o having broken the crank bolt. I managed to replace the drive belts, but not the timing belt--and sustained several cuts in the process.
Hyundai has room for mads and finger; Honda did not.
MS Fowler is offline   Reply With Quote Quick reply to this message
Old 02-07-2012, 08:01 PM   #6 (permalink)
Sonata YF
Elanham is an unknown quantity at this point
Did this a while ago on a 2004, best prices for all the stuff was Rock Auto. I did the water pump too as it is behind timing belt and car had 109K miles and figured it would start leaking one week after I put it all back together! Kind of tight between block and strut tower, timing cover can be a bitch to get back in right with the limited space and not lose the gasket placement.
Elanham is offline   Reply With Quote Quick reply to this message
