Headlight (lowbeam) issue - Hyundai Forums : Hyundai Forum
Old 11-04-2011, 12:09 PM   #1 (permalink)
2006 Elantra
brees6221 is an unknown quantity at this point
Default Headlight (lowbeam) issue
2006 Elantra
I've searched for this or similar issues and have read a few threads but I could use some help with a headlight issue.
Last night I was getting ready to leave work and my headlights stopped working. When I started the car and rolled the switch forward they flickered on very briefly and then turned off abruptly. I tried turning them off and on and restarted the car, neither worked. All parking lights work, tail and brake lights work and highbeams work. I ended up driving home with the highbeams on. This morning I picked up a new headlight and tried it in both the driver and passenger side with no luck.
I read in another thread something about replacing the relay. How involved is that? Does it involve cutting/splicing wires or is there a plug on both ends where it connects? Any idea how much a new relay runs?
I'm just looking for a few low cost/time possible fixes to try before paying a mechanic. Are there any other thoughts on what the issue might be? I'm convinced it has somethign to do with a fuse, relay or wiring. Thanks for your help!
brees6221 is offline   Reply With Quote Quick reply to this message
Old 11-04-2011, 10:32 PM   #2 (permalink)
2006 Elantra
Update - this evening I checked the fuses and they're fine. Using the diagram on the underside of the fusebox lid, I found two fuses marked H/L (HI) and H/L (LO). Since the highbeams are working and the fuses were identical I switched them but the highbeams still worked and the low beams didn't.
The diagram didn't have information about the relays, I'm still curious about those if anyone can help out.
Old 11-05-2011, 08:04 AM   #3 (permalink)
2006 Elantra
Edit - It looks like what I've been calling the fuses are actually the relays.
Old 11-06-2011, 01:46 AM   #4 (permalink)
2006 Elantra
Wow, don't everyone reply at once. Good thing I registered for this forum...all these views and zero responses. Way to go guys, you've made this a massive waste of bandwidth.
