2001 Automatic Transmission Shifting Erratically - Hyundai Forums : Hyundai Forum
Old 05-14-2011, 01:02 AM   #1 (permalink)
ghetto3jon
i have a 2001 elantra with 136k. the automatic transmission (which otherwise shifts very smoothly and shows no sign of problems) shifts suddenly and erratically when i'm driving at a constant speed. i'll be traveling along (speed doesn't matter), and it will suddenly downshift, then upshift, then downshift, etc. this started off being very occasional, but now it randomly shifts every 5-10 seconds.
i've changed and checked the fluid, and tried replacing the Input Speed Sensor and the Output Speed sensor...that didn't fix it. it also does not blow a check engine code. i'm convinced there must be a sensor somewhere that is faulty. it really seems as though the transmission is electronically confused.
any help is greatly appreciated.
ghetto3jon is offline   Reply With Quote Quick reply to this message
Old 05-14-2011, 04:43 AM   #2 (permalink)
jsinton's Avatar
Did you scan for codes? I would only be speculating to say that the range selector switch can do weird things when it goes bad.
Old 05-14-2011, 10:18 AM   #3 (permalink)
You need to access the TCM and see if any codes hiding in there.
Old 05-14-2011, 11:44 AM   #4 (permalink)
ghetto3jon
so take it to the dealer, basically. bummer.
Old 05-14-2011, 11:47 AM   #5 (permalink)
ghetto3jon
although maybe i'll try the range selector switch first if it's cheap. do you have a part number? i'm unfamiliar with that part. thanks so much!
Old 05-14-2011, 01:24 PM   #6 (permalink)
jfb777
QUOTE (ghetto3jon @ May 14 2011, 01:02 AM)
sounds like the transmission range sensor to me i had the same problem and it turned out it was that replaced it and it got a lot better and i did the speed sensors as well mine still does the erratic shifting here and there but i havent had the chance to adjust the transmission switch yet be sure to when u change out the sensors to get the codes wiped then drive 50 miles then check for codes again..
jfb777 is offline   Reply With Quote Quick reply to this message
Old 07-20-2012, 10:44 AM   #7 (permalink)
hyundai elantra 01
danielson3 is an unknown quantity at this point
Have an 01 elantra had the same problem.replaced the TPS throttle position sensor.completely fixed the problem.
danielson3 is offline   Reply With Quote Quick reply to this message
