Idle Air Control (iac) - Hyundai Forums : Hyundai Forum
Old 04-05-2011, 07:49 PM   #1 (permalink)
russell7
My car has been revving up to around 2-3k rpm upon startup... the mechanic says it's a faulty idle air control valve. He tried to clean it but to no avial--the car still revs up occasionally.
I can't find the IAC valce in the Hayne's Manual. Might it be called something else? The idle speed control actuator, perhaps? Is this is job for an industrious do-it-yourselfer?
The shop wants almost $300 for the part and $100 for labor... The IAC at at O'Reilly's is $115.
Thanks for your input!
russell7 is offline   Reply With Quote Quick reply to this message
Old 04-19-2011, 09:24 PM   #2 (permalink)
recian
it's simple to change having such a small engine and alot of room to get to the intake. It's near the throttle body usually behind it. I'd vote go get one from oreilleys and put it in yourself
recian is offline   Reply With Quote Quick reply to this message
Old 04-20-2011, 12:33 AM   #3 (permalink)
russell7
I still can't find it in the Haynes manual though...
Old 04-28-2011, 07:47 AM   #4 (permalink)
debora450
well u can get the manual easily from a local dealer..just check with them once..if u fail to do so then u can try ur luck in ebay or amazon.
debora450 is offline   Reply With Quote Quick reply to this message
Old 05-12-2011, 02:40 AM   #5 (permalink)
liter
the local dealer will sell you a haynes manual?
btw he said he still couldn't find it IN the Hayne's manual meaning he already has one.
in my experience the Hayne's manuals are all too vague, I like the Chilton's manuals but the funny thing is they are made by the same people! If you can get a look at a Chilton's(not sure if they even offer one) you may find more info.
Is there a sucking sound? start the car and spray carb cleaner along intake points and see if engine changes attitude, if so you've got an intake leak, it's quite common with these or any vehicle for that matter because an engine is basically an expensive air pump. wrong amount of fuel to air and they don't want to run right. check back with results.
liter is offline   Reply With Quote Quick reply to this message
Old 06-07-2011, 12:50 PM   #6 (permalink)
blueberry
Check your local library for a Chilton manual. They tend to carry them, though you might only be able to make copies of the section you need, since they generally keep them for library use only. We tend to fear oil spills and grease on those books, and they're quite popular with patrons.
blueberry is offline   Reply With Quote Quick reply to this message
Old 09-09-2012, 11:58 AM   #7 (permalink)
Drives Elantra
westgoingzax is an unknown quantity at this point
The Haynes Elantra manual calls it idle speed control actuator or ISC. Part stores call it the idle air control valve.
westgoingzax is offline   Reply With Quote Quick reply to this message
Old 09-09-2012, 12:29 PM   #8 (permalink)
You all in bad shape,, part in hand, locate the part that look just like it.. in this case with the 2.0 Elantra, it is on the plenum just beside the flange where the throttle body sits.. 2 bolts and a paper thin gasket is all there is to it..
Old 09-10-2012, 07:31 AM   #9 (permalink)
2006 Elantra 5spd
Norubit is an unknown quantity at this point
This is an old thread. I wonder how he made out.
Norubit is offline   Reply With Quote Quick reply to this message
