Heater Problems - Hyundai Forums : Hyundai Forum
Old 11-27-2005, 11:48 PM   #1 (permalink)
ride wake 210
hey,
somethin seems to have gone wrong with the blower control switch..the one with all the numbers that controls the speed of the blower or somethin like that..
well my positive battery terminal came off of my battery earlier at my work after my g/f and i got done watchin a movie and it worked fine then..and then it happend again at her house and now i have nuthing for heat..the core is hot because i can fel the heat through the vents but theres no air pushing the heat.
any and all help is greatly appreciated
thanks
sean
ride wake 210 is offline   Reply With Quote Quick reply to this message
Old 11-28-2005, 01:28 PM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
you will need to check whether you have got power going to the blower motor itself, use a meter or test light to determin this, this will rule out a faulty motor and/or switch, another possibility is the resistor which controls the blower speed
MONTEGO
Old 11-28-2005, 04:50 PM   #3 (permalink)
saugen48
Send a message via Yahoo to saugen48
Under the engine bonnet (mine is just behind the battery) is a fuse/relay box. According to the online pics at hmaservice.com, there is a 30amp blower fuse/relay.
K Blower 30A Pink
Check that out, yours may have blown
saugen48 is offline   Reply With Quote Quick reply to this message
Old 11-28-2005, 07:52 PM   #4 (permalink)
ride wake 210
im not sure wut happend.
its all working fine now besudes a few things
my cruize control button on the dash doesn't turn on anymore and my cruize quit working.
and also the lights for both the dials r out and same for the A/C button and the air flow button..im not sure if the button for the air flow-inside air or outside air- is even working or not
thanks guys
Old 02-22-2006, 03:36 PM   #5 (permalink)
Dragonmp5
Send a message via Yahoo to Dragonmp5
If the cruise is not working it's either a loss of vaccum or a bad fuse. Have these checked. The lights are out behind my dials as well but I'm not concerned about it just yet.
Dragonmp5 is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 09:49 PM   #6 (permalink)
ride wake 210
this is so old. i fixed everything on my own.
