Elantra Lifters Problem! Will 20-50 Oil Fix It + Work Ok?! - Hyundai Forums : Hyundai Forum
Old 03-08-2013, 11:54 PM   #1 (permalink)
Elantra 2000
Joaquin is an unknown quantity at this point
Default Elantra Lifters Problem! Will 20-50 Oil Fix It + Work Ok?!
Hey Guys,
I've had my car for 12 full years now, since December 2000 here in Puerto Rico, my car facts and issues:
My Hyundai Elantra 2000 facts...
- Always ran in Puerto Rico (temperature usually around 82-95 F usually all year)
- Once/Twice a month I pull my 750 LBS jetski + trailer since 2001
- 2001-2010 = 10/30 standard oil
- 2010-2013= mobile 1 full synthetic 10/30 oil (supposed to be good)
- Current miles = 84,000 miles
Issue I am having:
- Heavy lifters noise, BIG ONE since 2011
- I replaced with new ones in 2011 (they were charged correctly) and the noise still kept going immediately after installing all new lifters
- After the usual 4-5 months 10/30 mobile 1 fully synthetic oil change generally between 3,000-5,000 miles oil change, there's hardly any old oil coming out
- New synthetic oil gets in, but after 3-4 days the lifters start with the heavy noise again and the noise gets worse after using the car for 40-50 minutes on the road
I've been doing my research and among the many online suggestions from other lifter noise issues is to begin using 20-50 oil even if the user manual says 5-30 or 10-30 for typical cars like mine, but since my car is closing in to 100,000 miles soon and always is in hot weather...
..will changing from fully synthetic 10/30 oil to 20-50 think oil quiet down my lifters and NOT harm my car? I've read if it's supposed to be 10/30 or what the manual says it should be that, fine, but in my situation in Puerto Rico weather
and with the lifters ugly noise..will 20-50 oil do good to my car taking all of the above history in mind?
What you think?
P.S- Thanks in advance so much for your input, it means a lot! I just finished sanding down + primer, I'll now paint the car for the first time!
Joaquin is offline   Reply With Quote Quick reply to this message
Old 03-09-2013, 07:28 PM   #2 (permalink)
jsinton's Avatar
If you replaced the lifters and it made no difference, wouldn't logic dictate the problem isn't your lifters? Did you do a compression check? Sounds like new motor time.
Old 03-10-2013, 03:51 AM   #3 (permalink)
Em-squared's Avatar
Joaquin!
Fashionista.
Em-squared is offline   Reply With Quote Quick reply to this message
Old 03-10-2013, 02:26 PM   #4 (permalink)
Elantra 2000
Originally Posted by Em-squared View Post
Joaquin!
Thanks for the welcome
Old 03-10-2013, 02:33 PM   #5 (permalink)
Elantra 2000
Exclamation
Thanks for your input here. My mechanic did the changes which makes me re-think if he charge them right or did the job correct. I have not done a compression check and that has been suggested once yesterday online.
Here's an answer I recently received that might be interesting for both of us, I might not need a new motor actually, what you think? I did not change the cams when the mechanic added new lifters..
Another answer to my problem...
WRONG WRONG WRONG WRONG!!! NEVER use THICKER engine oil! You have internal issues here You cannot replace LIFTERS without changing the CAM along with it! LIFTERs are just small oi l pumps and get sludged Up with bad oil! use a THOROUGH motor flush and use MOBI LONE 0W-30 oil NOT THICKER OIL! You wil RUIn what you already have there. It was a MISTAKE to change the lifters without the cam as well. They wear TOGETHER over time. and the ORIGINAL lifters will only get CLOGGED UP and not wear out! BIG MISTAKE! It is POSSIBLE that the oil feed pores in your HEAD GAKSET are clgged up with slduge and prevent your lifters from getting oilat ALL! check the ROCKER and CAM bolts for torque. Those engiens are AWESOME and long lasting. NEVER use such THICK OIL or you will blow up the OIL PUMP and PISTON RINGS, too! GOOD LUCK anyways!
What you/you guys think of the above answer?
Will have in mind the compression check, I am still thinking that a motor flush and 20-50 oil might be good option for my end, now I am still trying to make final conclusions on whether 20-50 oil will harm my car/brake my engine.
I just sanded down the car and painting it for the first time, I am hoping a big motor change won't be needed.
What you guys think? Motor flush, compression check and 20-50 oil will do good?
I don't have much ideas here as I am not a mechanic, just trying to understand how this work so I don't make another bad decision on $spend$ mode of the car.
Additional seconds in answers will be soooooo appreciated!
Old 03-10-2013, 07:06 PM   #6 (permalink)
jsinton's Avatar
Don't waste your time with the 20w/50. If the motor is shyted, ain't no oil gonna help. Do the compression test, it will tell you all you need to know. Sounds to me like the motor is shot, and burns all the oil. Isn't there huge clouds of smoke?
Old 03-10-2013, 07:49 PM   #7 (permalink)
Elantra 2000
Will definitely do the compression test, just makes sense (as I don't even remember doing that anytime soon), but one thing that I certainly can confirm is that there ain't no dark/or white cloudy smoke.
Spent $270 on all the paint material + $500 to have it painted with me and a friend of mine, just can't start to imagine breaking this baby now..I even tow my jetski with this and absolutely no problems and never has left me walking..so can't quit on this car now.
I'm sure not buying more lifters now..must be something else, will exhaust all the possible alternatives this upcoming week and will see what I get from the mechanic.. $oh baby!$
Thanks a lot for the suggestions so far mate!
Old 03-13-2013, 08:27 AM   #8 (permalink)
EdGasket
Quote "change generally between 3,000-5,000 miles oil change, there's hardly any old oil coming out"
Can you clarify this please? Are you saying that between oil changes you don't check the oil level or top it up? If you have allowed the oil level to run low then that would explain why your top-end has worn.
10w/40 semi-synth is fine for these motors; they weren't designed for and can't take fully-synth; will burn it and leak it; probably why you use up all your oil and nothing much is left to come out at the next change.
EdGasket is offline   Reply With Quote Quick reply to this message
Old 03-13-2013, 11:17 AM   #9 (permalink)
'12 Elantra Sedan '12 Chevy Malibu '11 Kawasaki Vulcan 900 And yes, I drive them all.
Easy Rider is an unknown quantity at this point
Back to basics first.
Just exactly what does the above mean ??
Taken at face value, it sounds like you are never checking the oil level between changes and you are leaking or burning a LOT more oil now and if you keep doing that, you will eventually damage your engine beyond repair. The lifters are chattering due to a lack of oil !!!
In my opinion, it was a bad move to change to synthetic so late in the engines life. Not likely that was really the cause of anything but it might have made an existing condition worse.
At this point, I suggest a 10W40 conventional "high mileage" oil AND checking the oil at least twice a week. When it gets down to the add mark, change it again. After that, just add as necessary.
If you need to add a quart more often than every 1000 miles, there may be enough engine wear that there is nothing you can do to help the oil loss.
Also, forget that "motor flush" and other snake oil treatments. They will only make matters worse.
Easy Rider is offline   Reply With Quote Quick reply to this message
