LinkBack | Thread Tools |
#1 (permalink) |
MODERATOR
For every owner of a Terracan or Hyundai vehicle fitted with the 2.9 liter CRDi engine, beware of a sudden failure of the fan belt tensioneer pulleys.
The maintenance program in the owner's manual says nothing about this pulleys. Truth to be said, they should be replaced at the same time the timing belt is replaced, in order to take advantage of the labor cost, since they have to be removed in order to replace the timing belt. I am a careful owner and take good care of my cars. I had my Terracan's timing belt replaced at 90,000 kms, but since there was no advice about the fan belt tensioneer pulleys, I used the old ones again. Last Sunday, after a long trip (about 300 kms) on my way back, just two blocks away from my house, all of a sudden all the warning lights in the dashboard came on (fuel filter, brakes, vacuum and battery). I stopped immediately and checked. The problem was that the lower tensioneer pulley broke off, making the fan belt (accessory belt) jump out. Thank God it happened just arriving home and could just barely park in garage (no brakes!). This happened at 140,000 kms. I must say that since several days before, I kept hearing a muffled whining noise coming from the engine, which I first thought it was the transmission, but later discovered it was from engine. Terracan was towed Tuesday morning to my mechanic's shop (Monday was a holiday here). Upon inspection, the upper pulley was bad too, so both pulleys had to be replaced. New belt was installed since the old one got nicked. The whining noise is now gone, because it was coming from the worn out ball bearings inside the pulleys. From my conversation with my mechanic, he told me he has seen this happen many times, so they always advice their customers to replace both pulleys anytime the timing belt is replaced (every 90,000 kms). The attached picture shows "whats left" of the lower tensioneer pulley (yellow in the engine diagram), where the ball bearing simply got busted from wear. Both parts and new belt cost was around $180. Labor was $50, but if this is done while replacing the timing belt, it would not add to the labor cost. So, you Terracan owners, if your engine is past 120,000 kms and you notice a whining noise from the engine, which changes pitch according to engine speed, its time to have those pulleys checked and replaced.
Robert B. Don't forget to participate and vote in the February 2013 ROTM thread at http://www.hyundai-forums.com/249-ri...2013-rotm.html |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) | |
MODERATOR
According to my mechanic, both pulleys should be replaced. The upper one does not have the spring loaded mechanism to keep the correct tension of the belt (green in the uploaded photos and drawing). The lower one has the mechanism (yellow) and for some reason, the ball bearing in this one fails sooner than on the other, but nevertheless, it is advised to replace both, since the labor is about the same for replacing just the lower one. My suggestion is to contact your parts department and check if they have them in stock. Buy them of have them ordered, then, next time your car needs servicing, have them replace the pulleys. The pulley failure produces no harm to engine or car, unless of course you try to keep driving without brakes, water pump and alternator operation... What you do not want, is to get stranded in the middle of nowhere, trying to find a tow service to bring your car back home or the service shop, then finding our there are no parts available... Enough said!
#4 (permalink) | |
Drives Hyundai Terracan 2.9 CRDI, Ford ranger 2.2XLT
#5 (permalink) | |
MODERATOR
You are right. That's a data I forgot to include in my original post. Upper pulley: 46471-20010 Tensionner pulley: 25281-4X100 Main fan belt: 0K88R-15987 Pwr steering belt: 57161-H1500 (I am taking this part numbers from the service shop invoice)
#6 (permalink) |
terracan crtd
thanks for the info.i replaced my cambeelt and aux belts recently myself but didn't do the tensioners,never gave it a thought tbh. will watch out for the noise though and maybe do them as a precaution as at 87000 miles now.(139000kms)
#8 (permalink) |
As this thread seems to be of interest to those about to, or having just replaced timing belts, I would suggest changing the timing belt tensioners at the same time as the timing belt!
One week after the timing belt was changed by a Main dealer, the tensioner let go! bent valves and massive engine damage followed nanoseconds later. A large bill followed that some weeks later. Hmm, I wonder if the pulleys are made by the same company? The mileage was in the region of 150k, but that didn't mitigate my thoughts that the dealer should have changed the tensioners at the same time given the high mileage. |
#9 (permalink) |
Terracan
Thanks for that - mine has just done 127,000km - will keep an ear open for those noises! In view of large distances here in Australia will buy the 2 parts and put in my tool box - which is in Terry. Will then have them on hand if problem arises, or get them changed at next timing chain change.
#10 (permalink) |
Well, unfortunatelly my Terracan at 124.000 km cut the belt. Recently (115.000 Km) I changed this but not the tensioners (4), one of these broken, results 8 valves with the guide must be changed, a new belt with all tensioners, cost around US$1.270 (in Chile) ... :-(
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
