HP Fuel Pump - Hyundai Forums : Hyundai Forum
Old 08-02-2012, 03:24 AM   #1 (permalink)
Terracan CDX CRTD
1066man is an unknown quantity at this point
Default HP Fuel Pump
Hi All
Can anyone tell me if the Delphi fuel pump can be changed on a Terracan 2.9 CDX CRTD 2004 J type engine without removing the Cam belt entirely?
Also has anyone found an fault decoder that is compatible with this vehicle yet?
Tim
1066man is offline   Reply With Quote
Old 08-02-2012, 02:23 PM   #2 (permalink)
MODERATOR
RBURGOSS's Avatar
Originally Posted by 1066man View Post
Hi All
Tim
In order to be able to remove the high pressure pump, the cam belt must be removed. This pump is driven by the cambelt (timing belt), meaning the pulley (to pump) has to transplanted to the new pump. I would take this opportunity to replace the belt for a new one, plus the related parts like oil seals plus tensioner.
As for an OBDii scanner capable of digging "everything", I suggest shopping around for one of the high end scanners. I am sure none of the low cost ones (less than $100) will be able to retrieve everything).
Robert B.
RBURGOSS is offline   Reply With Quote
Old 08-03-2012, 05:24 AM   #3 (permalink)
Terracan CDX CRTD
Many Thanks Robert will do as you suggest. Tim
Old 11-20-2012, 04:29 PM   #4 (permalink)
Drives Terracan CRDI 55
f.milton is an unknown quantity at this point
Thumbs up Bosch diagnostic centres
Hi Tim,
I had an issue with my 55 plate, warning light came on on heavy load and accelerator. Took it to my local bosch diagnostic centre in worthing, told them I could fix it, but needed a diagnostic, only £25 and half an hour later they had a full report of over pressure in the rail.
There is one of these centres in Ashford Kent give them a try, on Ellingham ind est. I think.
Took off the injectors stripped them and they had a nice ultrasonic bath, back in, job done!
Fred
f.milton is offline   Reply With Quote
Old 11-21-2012, 05:04 AM   #5 (permalink)
MODERATOR
Em-squared's Avatar
Fred.
Fashionista.
Em-squared is online now   Reply With Quote
