Power Steering Fluid - Definitive Answer? Psf 3, Psf 4, Atf, Dexron Ii? - Hyundai Forums : Hyundai Forum
Old 03-23-2010, 12:30 PM   #1 (permalink)
Jeffceo
Thumbs up
Hi Everyone!
Does anyone have a definitive answer on what power steering fluid besides PSF 3/ PSF III or PSF 4 we can use?
No Hyundai dealers in my area sell the PSF 3 or 4. I have read on several posts that some people have used Dexron II/III automatic transmission fluid.
I have an 03 Tiburon GT V6. The original power steering fluid does have a reddish/pinkish brown color making me lean towards the automatic transmission fluid hypothesis.
Does anyone know for sure?
Thank you
Jeffceo is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 12:57 PM   #2 (permalink)
..MiamiLX..
The Manual lists all correct Fluids for use in your Car. Don't mix fluids!
..MiamiLX.. is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 01:54 PM   #3 (permalink)
Jeffceo
I have found a couple older manuals that specify "PSF-3, ATF Dexron II type fluid". This seems to indicate that PSF-3 and Dexron II are interchangeable. Please see the attached image of the lube chart from a 99 Sonata manual. Also in an online service manual for 1998-2000 Tiburons found here: http://www.newtonnet.co.uk/coupe/service/w...id=12802#_12802 it only mentions Dexron II.
However in my 2003 manual it only lists PSF-3. How could it be the same as Dexron III in 1999 but a few years later it is not?! Maybe it is just Hyundai attempting to force owners to purchase their fluid?
Anyone?
Old 03-28-2010, 02:41 PM   #4 (permalink)
2008 Sonata 3.3 LTD 2010 Dodge Ram 1500 Hemi 1995 Ford Taurus GL 2009 Sonata 2.4 GLS
ken99 is an unknown quantity at this point
QUOTE (Jeffceo @ Mar 23 2010, 11:54 AM)
Anyone?
Yes, Hyundai panders to the dealerships by specifying their own brand named products where ever possible.
PSF3 is (or was) Dexron II ATF. I have substituted Dexron III for Dexron II with no problems. If you read the fine print on the Dexron III bottle, you will usually find a statement that the contents are compatable for application specfying Dexron II and/or III fluids. Dexron III was an improved version of II with better oxidation charateristics. There is a new ATF called Dexron VI, that is a semi- or full synthetic that is specified backwards compatable with Dexron II or III. I have not used Dexron VI as a substitute for PSF3.
ken99 is offline   Reply With Quote Quick reply to this message
Old 05-26-2013, 06:54 PM   #5 (permalink)
Sante FE
praneshpal is an unknown quantity at this point
Default PSF-3 & PSF-4 ans Substitute
Originally Posted by Jeffceo View Post
Hi Everyone!
Thank you
Refer to http://www.google.com.au/url?sa=t&rc...ZBiF8_KE7vdnZg
This will give you an idea of what to use.
praneshpal is offline   Reply With Quote Quick reply to this message
Old 01-28-2014, 11:30 AM   #6 (permalink)
Drives: 2008 Entourage
buckie_F is an unknown quantity at this point
just sayin'
Psf-4
buckie_F is offline   Reply With Quote Quick reply to this message
