Timing Belt Replacement For 2006 Hyundai Tucson - Hyundai Forums : Hyundai Forum
Old 10-29-2009, 11:13 AM   #1 (permalink)
beachgirl11937
Hi,
I have a 2006 Hyundai Tucson 2.7 4x4 which I like very much. It just turned 61,000 and I have been told I should replace the timing belt. I really dont have the funds right now to do that, would anyone know how critical it is to do this at 60,000 miles or do I have a little more mileage before I should do this?
Thanks.
beachgirl11937 is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 11:25 AM   #2 (permalink)
MODERATOR
Drives: Accent MC (gone but not forgotten.)
If you wait, one of two things could happen: *Nothing, or the belt could break and you would be out thousands to replace the engine instead of a few hundred to replace just the belt. *If it breaks, there will be damage done to the valves and various other internal components, which will not covered under warranty.
Ride Of The Month
Forum Rules
hoosieraccent is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 11:30 AM   #3 (permalink)
beachgirl11937
QUOTE (hoosieraccent @ Oct 29 2009, 11:25 AM)
I was told that this job done at the Dealer would cost between $700-$800 because they would also replace the water pump at the same time. I wish it was just a few hundred dollars, then it would not be a problem.
Thanks for your reply.
Old 10-29-2009, 12:01 PM   #4 (permalink)
jsinton's Avatar
QUOTE (beachgirl11937 @ Oct 29 2009, 11:30 AM)
Tell them you don't need a water pump. Ask around and get a better price from a small garage.
Old 10-29-2009, 02:34 PM   #5 (permalink)
ausom accent 9's Avatar
2009 Accent SE
ausom accent 9 is an unknown quantity at this point
QUOTE (beachgirl11937 @ Oct 29 2009, 10:13 AM)
Hi,
Thanks.
Isn't there a forum for Tuscon??LOL
ausom accent 9 is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 03:40 PM   #6 (permalink)
ADMINISTRATOR
Montego's Avatar
QUOTE (ausom accent 9 @ Oct 29 2009, 07:34 PM)
yes, of course there is and l am moving it now
MONTEGO
Old 10-30-2009, 08:32 PM   #7 (permalink)
vizlay
700-800 dollars is outrageous for timing belt replacement. If you are just replacing the belt it should be 300-400 to get the job done. The 2.7 is a great motor and it will not hurt for you to wait on the replacement for now. Ive seen 2.7's go a long ways on the original belt, but better safe than sorry.
vizlay is offline   Reply With Quote Quick reply to this message
Old 10-31-2009, 01:21 PM   #8 (permalink)
Nikonian
It makes sense to have the water pump replaced at the same time as the timing belt. If your original pump fails before your next belt renewal, it could snap the belt. Also, if the pump does fail, you will need a new belt again!
Nikonian is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 11:24 PM   #9 (permalink)
rdkillians
we replaced t-belts and drive belts on tucsons for 375... 7-800 is crazy.
I have very rarely seen water pumps go bad on the 2.7l, but they are driven by the t-belt. my opinion is to
replaced them at 120 not 60.
besides if you are the original owner and the pump goes bad before 100k then its covered by powertrain.
rdkillians is offline   Reply With Quote Quick reply to this message
Old 04-02-2010, 10:59 PM   #10 (permalink)
vjiori
Is it true that the belt must be a Hyundai Genuine part? I'm in the same situation as this person, extended unemployment and wanting to get it done soon but as cheaply (reasonably) as possible.
vjiori is offline   Reply With Quote Quick reply to this message
