Strut Top Roller Bearing - Page 2 - Hyundai Forums : Hyundai Forum
Old 05-08-2010, 05:36 PM   #11 (permalink)
fivish
The offside collapsed and was replaced under warranty.
Then the nearside collapsed and was replaced under warranty.
Now the offside has again collapsed and its out of warranty!
The Trajet is coming up to 6 years old and has only done only 33,000 miles.
What do they make these things out of?
fivish is offline   Reply With Quote
Old 05-16-2010, 03:11 PM   #12 (permalink)
flip117
QUOTE (Hyundaiownersclub @ Apr 13 2009, 06:13 AM)
Email me through HOCGB with your chassis no and when I get chance I will put the mod up on that forum.
Hi, you wouldnt happen to have any of the covers left ?
thanks phil.
flip117 is offline   Reply With Quote
Old 05-17-2010, 12:50 PM   #13 (permalink)
andycarter's Avatar
andycarter
Send me a private message with your name and address and I'll pop a couple in the post.
Andy
andycarter is offline   Reply With Quote
Old 07-10-2010, 05:33 AM   #14 (permalink)
dandaz2
hello
I think i have this problem , but the dealer said it was £87 for the part ,he called it the "top mount strap"...
The steering clicks and with warrenty we have had this done twice....
is it the same thing?
dandaz2 is offline   Reply With Quote
Old 07-10-2010, 06:12 AM   #15 (permalink)
dandaz2
oh and what is HOCGB?
Old 07-13-2010, 04:12 PM   #16 (permalink)
andycarter's Avatar
andycarter
£87 sounds like the price for a strut top mount / bearing
QUOTE (dandaz2 @ Jul 10 2010, 11:12 AM)
http://www.hyundaiownersclub.co.uk/
Old 11-19-2012, 09:57 AM   #17 (permalink)
2001 Trajet FO 2.7 GLS comfort 1996 Sonata Y3 3.0 GLS
e3tom is an unknown quantity at this point
Good question.
Last Saturday I have replaced both sides again - after 2.5y & 12000km only.
The ball bearings were still good, the left a little noisier but far from broken. The problem I had was the rubber. This got squeezed so much that the upper spring pad touched the mounting plate of the strut mount and was scratching and binding there, feelably impacting steering (and of course making clunking noises when turning the steering wheel).
No wonder though if seeing that the part is the same as on the Y3 Sonata - but the Jet weighs min. 400kg more.
The old and new were from Kayaba (KYB ). Hope they improved the material in the meantime. Are there any other manufacturers known to be better than the KYB parts ? Just in case I need new ones again in 2 years from now ...
e3tom is offline   Reply With Quote
Old 11-20-2012, 02:26 AM   #18 (permalink)
MODERATOR
trajetXG's Avatar
Drives: A 2008-7 Seaters Santa Fe CM
trajetXG is an unknown quantity at this point
Originally Posted by e3tom View Post
Good question.
KYB is the right choice...
Hyundai...Drive your way.
trajetXG is offline   Reply With Quote
Old 11-21-2012, 04:49 AM   #19 (permalink)
jkausdu
Same problem with my Trajet, because of the water problem the bearing on the left was changed twice. Still no problems with the right side, it's the original one after 130.000 KM.
Here in Germany the "suspension mounting kit" from KYB ist not very expensive ( 35 € ). The Kayaba number is SM 5194.
jkausdu is offline   Reply With Quote
Old 11-24-2012, 06:41 AM   #20 (permalink)
Trajet XG 2000 GLs
mazen
Hi All
once a year I put some grease and a few drops of oil at the bearing . Just remove that coin size plastic cover and service it . My Jet is 12 years and never had this problem .
Regards
mazen is offline   Reply With Quote
