Trajet Drive Shaft - Hyundai Forums : Hyundai Forum
Old 10-31-2007, 01:00 AM   #1 (permalink)
kelvinvijayakumar
Hello everybody....
My ride is a trajet 2.0 gls yr 2002 model. Currently hitting 122000 km.
recently about 2 weeks , noticed nose from the rh wheel when turning at low speed. After inspecting noticed cv boot broken .
Contacted local agent, they have confirmed that the cv drive joint is faulty.
the issue is .
1. do one need to change both the drive shafts lh and rh...
2.Can the cv joint be repaired
I know for a fact that , the problem does not cause any danger to driving the car, nothing would just drop off, it just that the irritating noise when turning.
anybody has similar problems
kelvinvijayakumar is offline   Reply With Quote Quick reply to this message
Old 10-31-2007, 01:42 AM   #2 (permalink)
ssonata78's Avatar
ssonata78
They can do one side only if it failed prematurely. I have even heard of replacing the whole rotor and axle as well since labor would be more expensive taking it all apart. But that was on another vehicle. So If you didnt see damage I would say are you sure its not vibrating accross to the other side of the engine bay and making it seem like its from the right but I assume a good indicator is the broken boot. Did you check the other side too?
Steve
ssonata78 is offline   Reply With Quote Quick reply to this message
Old 10-31-2007, 05:28 AM   #3 (permalink)
admin's Avatar
admin is an unknown quantity at this point
Welcome
The secret of success is constancy of purpose ~ Disraeli
admin is offline   Reply With Quote Quick reply to this message
Old 10-31-2007, 06:24 AM   #4 (permalink)
will's Avatar
will
will is offline   Reply With Quote Quick reply to this message
Old 11-05-2007, 10:25 PM   #5 (permalink)
kelvinvijayakumar
ok. here is the deal .....
got back from local hyundai agent .... who claim they don't stock the drive shaft here in australia for imported cars .....sop...
need to get this from singapore , It a very expensive part $S972 for on side only...
well need help here, any bro willing to ship this to me ....PM me.
Old 11-06-2007, 06:11 AM   #6 (permalink)
MODERATOR
trajetXG's Avatar
Drives: A 2008-7 Seaters Santa Fe CM
trajetXG is an unknown quantity at this point
Originally posted by kelvinvijayakumar@Nov 6 2007, 11:25 AM
[b]ok. here is the deal .....
[snapback]117500[/snapback]
Give me the part number, let me check with the stockist here. If possible, provide me your chassis number too.
Hyundai...Drive your way.
trajetXG is offline   Reply With Quote Quick reply to this message
Old 11-06-2007, 10:12 AM   #7 (permalink)
Vtim
I paid S$300++ (including installation) for a pair of recon drive shaft (drive shaft are recon but both CV joint ends and boots are new parts) here in Singapore.
Vtim is offline   Reply With Quote Quick reply to this message
Old 11-07-2007, 12:03 AM   #8 (permalink)
kelvinvijayakumar
I was told by hyundai that the shaft for Trajet is a single piece item and one that cannot be interchange or change parts .....
Are you refereing to trajet shafts or any other?
Would really like to take you advice and change only the cv joint and boots ? where did you do this bro?
Old 11-07-2007, 11:52 PM   #9 (permalink)
kelvinvijayakumar
the saga continues .....
Today got my Trajet to a specialist who only deals in cv joints.
They took off the shafts and cv joints , and confirm the cv joints can be replaced ..what a relive.... and now i know i was smoked by hyundai .
The cv clinic guys are taking the mitsubishi magna 2.4 l cv joints , which are identical in part number to the my Hyundai trajet 2.0 cv joints.
They also confirm that the shafts need not be changed unless the shaft itself was damaged by a crash or etc. there is no way a shaft would wear down.
Old 11-11-2007, 10:08 AM   #10 (permalink)
Vtim
yah, the shafts do not need to be replaced unless they are bend or damage due to accident.
so how much did you pay to replace the CV joints, boots and installation in down under ?
