Transmission problem - Hyundai Forums : Hyundai Forum
Old 10-01-2012, 12:44 PM   #1 (permalink)
Drives Trajet CRDi 2.0 AUT
bathory is an unknown quantity at this point
Default Transmission problem
Hi Everyone!
Please, help me!
I have a trajet automatic diesel 2.0 (2003)
I love it
The only problem is the automatic transmission.
Sometimes, it is working perfect while sometimes it doesn't
go chang to 2nd. I have no idea why.
If I try more times hardly it change to 2 and 3 than it doesn't go above it. So, I drive a lot in 3 hundreds km.
I changed the oil, so it is new.
So, it is working well than somethings is happen and the problem comes out again.
Thank you very much.
bathory is offline   Reply With Quote Quick reply to this message
Old 10-01-2012, 10:43 PM   #2 (permalink)
MODERATOR
trajetXG's Avatar
Drives: A 2008-7 Seaters Santa Fe CM
trajetXG is an unknown quantity at this point
Most probably is the transmission sensor spoil...Is the check engine light ON?
Hyundai...Drive your way.
trajetXG is offline   Reply With Quote Quick reply to this message
Old 10-02-2012, 12:10 AM   #3 (permalink)
cubawashere's Avatar
05 Accent 1.6 automatic POS
cubawashere is an unknown quantity at this point
Bathory you may want to checkout this other thread. Your symptoms are similar to the job I did in my album on my profile here...
P0734 1.6 Transmission Issue
cubawashere is offline   Reply With Quote Quick reply to this message
Old 10-02-2012, 04:51 AM   #4 (permalink)
Thank you for your advices!I will try to fix it!;-)
Old 10-02-2012, 02:10 PM   #5 (permalink)
Trajet XG 2000 GLs
mazen is an unknown quantity at this point
Hi
Read the error code to know if a sensor or solenoid needs changing .
mazen is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 02:28 PM   #6 (permalink)
Army's Avatar
Army is on a distinguished road
Do you think the Tucson smooth 5-speed gearbox which is not 4-wheel drive may be good for the Trajet?
The engine type D4EA and both have very similar visually.
tucson transmission
Trajet transmission
Because of its real Trajet Tucson 103kW to 82kW only think of Tucson stronger gearbox can be made ​​more durable. The engine fixture from a shape seems to me completely. The rest of the fixture can be converted only to be good right? What if the engine is stronger in Tucson is the same engine type? Bigger turbo? could also Trajet to 112kW factory overclock? Of course, without an engine replacement.
Army is offline   Reply With Quote Quick reply to this message
