Hyundai Matrix 1.6 GLA engine CHECK light blinking and car shaking - Hyundai Forums : Hyundai Forum
Old 11-18-2012, 05:06 AM   #1 (permalink)
Drives Matrix
ivan99 is an unknown quantity at this point
Default Hyundai Matrix 1.6 GLA engine CHECK light blinking and car shaking
Hi and good day.
My Hyundai Matrix engine CHECK light is blinking when I am driving. It flashes then stay constantly on for a few seconds and flashes again. As I drive, I can feel the car vibrating under my legs. It really scares me. I tried adding water to the reservoir and engine oil seems enough but nothing seem to change.
What is the problem?? Really appreciate any help here, thank you!
ivan99 is offline   Reply With Quote
Old 11-19-2012, 11:23 AM   #2 (permalink)
Drives Matrix 1.6 2003
ronjonjim is an unknown quantity at this point
Sounds like you have a misfire on one of your cylinders. If you have a code reader it will tell you which one(s).
ronjonjim is offline   Reply With Quote
Old 11-20-2012, 02:27 AM   #3 (permalink)
MODERATOR
trajetXG's Avatar
Drives: A 2008-7 Seaters Santa Fe CM
trajetXG is an unknown quantity at this point
Check your spark plug...
Hyundai...Drive your way.
trajetXG is offline   Reply With Quote
Old 12-09-2012, 08:57 PM   #4 (permalink)
lkhakim
Pls check your spark plug Cable too
1. Check the cap and outer shell for crack
2. Measure the resistance with AVO meter,
resistance should not be higer than 10K ohm per foot of cable
if resistence is higer, replace the cable
lkhakim is offline   Reply With Quote
Old 01-12-2013, 10:24 PM   #5 (permalink)
Matrix 1.6A
syadlan is an unknown quantity at this point
i have this problem before.. after replace crankshaft sensor and it is ok already
syadlan is offline   Reply With Quote
