Reset Ecu On Getz - Hyundai Forums : Hyundai Forum
Old 05-23-2008, 02:19 AM   #1 (permalink)
ahnah's Avatar
ahnah
What is the easiest and yet recommended method for resetting the 1.4Auto Getz ?
ahnah is offline   Reply With Quote
Old 05-23-2008, 03:48 AM   #2 (permalink)
oliver1982's Avatar
oliver1982
Originally posted by ahnah@May 23 2008, 04:19 PM
[b]What is the easiest and yet recommended method for resetting the 1.4Auto Getz ?
[snapback]163282[/snapback]
I did this before when I had issues (although it turned out to be ignition leads).
It was very easy but I can't comment if it's the best way to do it...I just saw it on the net somewhere. I don't know much.
Open the bonnet and look towards the "top right", there's a black box which I think says FUSES on it or something like that. Open the box by unclipping it and remove one of the little things in there (I think it is either red or yellow). Check your instruction manual to find the right one to remove (in the specifications section there is a diagram of the fuse box).
Anyway, take it out and replace it after a few minutes (can't remember how long so give it 30 mins just to be safe).
If you are missing your instruction manual then let me know and I'll have a look in mine. I can't be bothered right now as it's too cold lol
oliver1982 is offline   Reply With Quote
Old 05-23-2008, 01:03 PM   #3 (permalink)
ADMINISTRATOR
Montego's Avatar
just remove the battery ground cable for a few mins.
MONTEGO
Montego is offline   Reply With Quote
Old 05-26-2008, 02:02 AM   #4 (permalink)
ahnah's Avatar
ahnah
both negative and positive battery ?
any other method ?
how abt take out the ECU fuse ?
Old 05-26-2008, 04:39 AM   #5 (permalink)
oliver1982's Avatar
oliver1982
Originally posted by ahnah@May 26 2008, 04:02 PM
[b]both negative and positive battery ?
any other method ?
[snapback]163961[/snapback]
Either way will work...but you will have to reprogram your stereo settings if you disconnect the battery though, but no big deal.
Not sure if you take off both the positive and the negative. I would though...not going to do any harm, so why not?
Old 05-26-2008, 04:43 AM   #6 (permalink)
ahnah's Avatar
ahnah
Originally posted by oliver1982@May 26 2008, 04:39 PM
[b]Either way will work...but you will have to reprogram your stereo settings if you disconnect the battery though, but no big deal.
Not sure if you take off both the positive and the negative.* I would though...not going to do any harm, so why not?
[snapback]163979[/snapback]
memory from headunit will lose ? ?
then I better dun touch the battery ...
anyway to reset ECU without affect the HU and stereo settings ?
Old 05-27-2008, 02:46 AM   #7 (permalink)
oliver1982's Avatar
oliver1982
Originally posted by ahnah@May 26 2008, 06:43 PM
[b]memory from headunit will lose ? ?
[snapback]163980[/snapback]
Just take the fuse out (see my first reply)
Old 06-01-2009, 03:27 PM   #8 (permalink)
francarl
Anything written above will work since all of them remove the supply to the ECU. Where is the ECU of the Getz? I could not find it...
francarl is offline   Reply With Quote
Old 06-02-2009, 04:52 AM   #9 (permalink)
blackbullet's Avatar
blackbullet
Yeap, pull out the ECU fuse and wait around 30min before putting it back in...
Straights are for FAST CARS
Corners are for FAST DRIVERS
blackbullet is offline   Reply With Quote
