LinkBack | Thread Tools |
#11 (permalink) |
Drives Getz
Unfortunately I have the very same problem with My Getz--the radiator fan only works when the air conditioner is engaged--I have printed off the PDF but have no idea how to test the ECT-(Engine Coolant Temperature--would appreciate any help in this matter
huffyb
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) |
MODERATOR
Using the GETZ ECT SENSOR TESTING.PDF as reference, you will need an ohm tester (digital) and a thermometer (precision). If you have an OBDii scanner will be best.
First, locate ECT sensor according to your engine. PDF attached to post #8 in this thread will help you locate it. Remove it and test following the GETZ ECT SENSOR TESTING.PDF. Suggestion: Before removing sensor, check that its connections are OK, and there is no rust of gunk inside connector. Check cables too.
Robert B. Don't forget to participate and vote in the February 2013 ROTM thread at http://www.hyundai-forums.com/249-ri...2013-rotm.html |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
