LinkBack | Thread Tools |
#1 (permalink) |
i have a 2005 1.6 Getz, it has just passed 90000km. I realise the timing/driving belt needs replacing, but am not is a position to afford it yet. How long can I realistically delay before I have to change the belt??? I don't gunn the engine and drive quite sensibly, and only for short distances. Any help / information would really be appreciated
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
MODERATOR
QUOTE (Ian me @ Jun 7 2011, 07:10 AM)
How long can you delay replacing the timing belt? I guess that question can be answered only with a crystal ball, a tarot deck of cards and your horoscope. There have been cases of broken timing belts as short as 50,000 kms or engines with half a million kms and still running with the original belt. The bad thing here is that like brain aneurism, there are no symptoms to look for before the disaster strikes. Changing the belt is not that difficult (not that you can doit in your home garage). Any good shop can do it. One way to minimize cost is to go get some parts now, then the rest of the parts next month. Shop around for the labor and plan it do be done in the next 3 to 4 months. That way your costs will be diluted in time. In the meantime, drive gently and stop your engine at the slightest symptom of mechanical failure. Robert B.
Robert B. Don't forget to participate and vote in the February 2013 ROTM thread at http://www.hyundai-forums.com/249-ri...2013-rotm.html |
#3 (permalink) | |
ADMINISTRATOR
QUOTE (Ian me @ Jun 7 2011, 01:10 PM)
acording to hyundai service schedules the timing belt should be changed every 60,000 miles (96,000 k/m) or five years whichever comes first, leaving it longer than this is like playing russian roulette with your engine. if the belt was to break it will make a very large dent in your finances
MONTEGO """""""""""""""""""""""""""""
#4 (permalink) |
Timing belt is a crucial part of the car its failure may cost you overhauling the engine please check out the play of timing belt or refer users manual to check with the timing bel or else get somebuddy who have getz with recent history of timing belt chenge and just use your fingure to check the play (Elasticity of belt).. and thempare with your one.... whenever you change your timing belt check out howm much tooth the belt have and accordingly buy new one.. also regualarly cheeck for severe abrasion or cracks on the belts...
#5 (permalink) |
Drives Getz
I have the same concern. I have a Getz 2005 model and only has 44KM. It will turn 7 years this july.
I have asked several people their point of view or experience when it comes to changing timing belts and they say 'they usually consider the mileage'. Now based on your answers, I am starting to doubt again. Do you have steps or illustrations how to check if the Timing is still in good shape? Thanks in advance. |
#6 (permalink) |
Sells, Veloster, i45, i40, Santa Fe, ix35, i30, Elantra, Accent, i20
Cost of timing belt is by far smaller than the cost of repairing the engine.
at the 90,000 km service in australia, its includes oil and filter brake fluid and clutch fluid *if manual* transmission fluid *if auto coolant change air filter spark plugs timing belt if your finances are a little tight, you can always break this service up, and start with the most important first, timing belt, then in a month or twos time do some of the rest |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
