Hyundai Getz 1.5 Cdri 3 Cylinder - Hyundai Forums : Hyundai Forum
Old 01-09-2011, 07:45 AM   #1 (permalink)
cfjooste
Hi Everyboddy
Can someone HELP with my problem.
My car the Hyundai Getz 1.5 CDRI 3 Cylinder is hard starting when enjin is gold and refuse to start when enjin is hot.
I have replace the following already: oil sensor unit, cam sensor, injector pump, fuel converter, program a new key, service the vehicle, and the compression is very good.
No one can find the problem not even the agents.
Can anyone HELP please.
cfjooste
cfjooste is offline   Reply With Quote Quick reply to this message
Old 01-09-2011, 09:02 AM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
welcome to the forums
l am moving your post over to the getz forum for a better response
MONTEGO
Old 01-10-2011, 02:08 PM   #3 (permalink)
Hyundaiownersclub
QUOTE (cfjooste @ Jan 9 2011, 12:45 PM)
Hi Everyboddy
cfjooste
Check the throttle housing for gunge and give it a good clean inside with carb cleaner. You will have to remove it to do the job properly
HYUNDAI TECHNICIAN BASED IN ESSEX UK. ALL HYUNDAI REPAIRS/MODS UNDERTAKEN INCL ENGINE/GEARBOXES Hi Scan and GDS equipment... www.hyundaiownersclub.co.uk / www.essex-tech.co.uk
Hyundaiownersclub is offline   Reply With Quote Quick reply to this message
Old 01-21-2011, 06:03 AM   #4 (permalink)
Ediaan
It was utterly unnecessary to replace all your sensors.
My 1.5 CRDi had the same problems and the useless greasemonkeys at the dealership mumbled something about getting a new Bosch injector pump costing ZAR 35,000. (That's about 3,500 GBP)
Anyway, I replaced a couple of other things like the diesel filter, etc. only to find out (after about 6 months of trouble) from diesel specialist company in Johannesburg, South Africa that the actual problem was one of my injectors that was dirty and they cleaned it.
It cost me next to nothing to have them cleaned and I've been driving it for nearly two years now withou any problems.
I have just over 135,000kms on the clock.
Ediaan is offline   Reply With Quote Quick reply to this message
Old 01-31-2011, 06:45 AM   #5 (permalink)
David Schultz
Hi There,
I had the exact same problem ( But mine just stopped working ).
Car eventually didn't want to start. The dealership also said, replace this and that ect, there is about a 20year gap as to test procedures, if something doesn't work they just want to replace.
Well my car is running smoothly now and all is good. Look up the following , diesel Specialists pretoria , or call me on 0832287641 and i will provide you with his number, this place fixed my vehicle in a week and Half where Hyundai couldn't in 5 months!
Hope you come right.
Regards,
David
David Schultz is offline   Reply With Quote Quick reply to this message
Old 05-27-2013, 01:19 PM   #6 (permalink)
Drives hyundai getz 1.5 crdi
marcel.rossouw is an unknown quantity at this point
.Hi there,
I have the same problem I replaced the fuel pump on the diesel thank,fuel filters,crank sensor,injectors,fuel pump etc..And still it wouldn't start I even bought a new engine and still my car doesn't start.
Can anybody please help?
Kind regards.
M.R
marcel.rossouw is offline   Reply With Quote Quick reply to this message
